i doubt it man.
i honestly think port noise is a myth cause ive built boxes with only 1" of port width with 0 noise.
IVE NEVER had port noise.
port noise does exist but the post after this by Raytard is exactly what i would say
port noise occurs mostly at higher volumes
so a good sub like that FI you got there, beating with all that wattage moving a shitton of air may very well give you turbulence, and you will hear it in the form of whooshing for lack of a better term if you open your trunk and listen at a higher volume
at lower volume, or with junkier subs, it doesnt matter, because they arent moving enough air fast or far enough to cause turbulence, thats why those nice little prefabs with kicker comps or rockford p1's off 200 watts dont make port noise.
if its in your trunk, and you're in the car, you probably wont hear it, so dont worry, just something to consider for your next box. Try to keep the port as square as possible, the longer and thinner it gets, the more likely you are to have port noise.
(i had a 1.5x14.5 port in my last box, lots of port noise on low notes at high volume)
9:1 hxw ratio MAX is a good rule to follow......if i put one of my subs in a box like that and gave it ANY kind of power, it would sound like a kazoo whistlin' dixie.
yeah but if i trim come off, i might as well just use 12. just wondering so i can know to pick some shit up
not true, the legnth of the run is the important thing. Trimming some off to fit in a terminal wont hurt anything. For you though and most others, 12ga is perfect anyway.
Follow my Tweet (Twitter)
the run will only be from the sub to the amp, and you think 12 ga will be ok. Cuz if you say it ill go pick some up. And Btw your Cadillac Build blows my mind (assuming its not done) Thanks
why buy more stuff when you have what you need? not to be a jerk, but i think your over analyzing things. thats just fine, but theres a point where ya gotta just do something. i wouldnt buy more materials when you have what you need.
If you've been doing something for 20 years, does that mean what you do it right???
__________________________________
Want:
2x Phoenix Gold RSD65CS
Comp Amp Undecided
AA Havoc
AQ 1200
knu wiring
set scew lugs for all connections
Alpine IDA-X303 2v preout :(--this goes under the seat.
Have:
Alpine tape deck w/ Benzi Box and 6 disc changer
Check out my Toyota build
i'm just trying to get it right you know i may be over anylzing things, cuz if i dont worry about stuff i may do a stupid mistake that might cost me 100's of dollars. And i have some Stinger Pro Series 12 guage, but im going to the shop anyway to get some terminals and im sure ill ask for some 12 guage and they'd just give it to me. But i understand what your saying, im just trying to do the best job i can
well a great choice in sub for a first build. i know how ya feel with messing with the plastics of the car and stuff tryin not to fuck any thing up. I was like that with my first system too, once i got a nicer car. I agree that the port is a little thin. I'd reallly like to hear how it sounds and the aftermath of completing this project. you should put some vids of the xmax and what not on the tube when your done and post em up hurr. 12 guage speaker wire is fine bro. lets get some picccccsssss of the sub and finished product :clapping:
So heres another update, didnt finish tonight like i wanted to. Some things came up, anyway heres the pics.
First i had to drill a 3/8" hole into these, cuz they didnt fit over the Stocked HC800 terminals.
Posted Image
Quick Test Fit
Posted Image
Like a Glove, theres a little lip where the light is
Posted Image
another
Posted Image
Tried to Wire it while it was in the trunk
That wasnt working so ill pulled it out
Posted Image
The BL in the box
Posted Image
My attempt at "Flushiness" It worked out well i think
Posted Image
In Da Trunk, (friggin thing weighs a ton)
Posted Image
Posted Image
Got the amp put on the box, but the ground screw wouldnt budge so i had to pull it out
Posted Image
and that was the end of my night, and i gotta get something to pick up all that copper...
Cute Doggy.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
a shop vac or a vacuum cleaner with a hose should get those copper trimmings
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
Ok so an update couldnt finish because my t-1000-1's ground screw was like wedged in their, took it to Vibez, my local shop, and they took care of me like always. so i work all day tommorow and tonight, but SUNDAY i dont work at ALL :yahoo: itll be done. WITH more pics and vids i promise. So see you then.
