i think picked up .2 on the TL using duct tape around the woofer
Team sundownWESTCOASTSPL.COM we're throwing dbdrag events very soon visit the website for details
duct tape fixes anything
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
RTV works well, but will be hard to peel off later should you need to.
I would use a strip of rope caulk around the perimeter of the enclosure which the subwoofer mates up with. This should seal well and will remain pliable and easy to remove later if you need to take the sub out. You can get it at any hardware store, look in the weather stripping area.
2001 Chevy Blazer
(2) SAZ-3000Ds
(2) custom 18" Madmax subs in a second row wall
Rockford 600-4
Pioneer PRS components
Pioneer P800PRS deck
I don't know how to say it in english but i'll give it a try,
I used (thick) double sided tape to seal my enclosure behind the sub.
something like this:540888_BB_00_FB.EPS.jpg
if that dont work just make a bead of clear caulk around the indside of your screw holes.. use your finger and flatten it out a little bit.. and make it uniform.. let it setup and dry before you reinstall the woofer.. should seal really good.
91 dodge colt gt..
4 custom t600 15s
audioque 3500d.1
tuned to 25 hz... stay tuned.
blazer
stroker 15
brutus bxi2006d terrible voltage drop
145.4@38HZ... SEALED LEGAL
Aim: chewieft09
www.t3audio.com
carpe diez nuts !!
my house is louder than your car...
I've done the same. Worked great, just like RTV.LOL
