Mustang Build Log- NEW VIDEO
Mounted the ignition box for easy access
Posted Image
Posted Image
Posted Image
also added some more gauges angled up so you can see them better out of the corner of your eye.
Posted Image
Posted Image
Posted Image
Posted Image
also cleaned up some wiring, put everything in a central waterproof relay/fuse box.
Posted Image
Posted Image
Of course I went with a lightweight XS power battery, fits nice and snug in the spare tire well. It will get covered with carpet, and no one will even know it's there.
Posted Image
Posted Image
Put the on/off switch in the liscense plate so it's NHRA legal.
Posted Image
Posted Image
im slowly building a 71 buick with a single turbo 455, were gonna hafta run when shes done ;)
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
damn man yall do good work this is lookin nice.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
This is looking better and better everytime I see it. But I have one concern though about your turbo mount. Since the eninge is connected to the frame by bushings (allow movent from side to side), and the turbo is hard bolted to the frame (no movement), do you have anyworry that either:
A. The turbo mount is going to brake off
B. The turbo tubes are going to bend and crack over time
Just wondering what your plans are for that.
formerly known as Blue86f150
this sux camel dicks
I'am guessing solid motor mounts........ Was kind of think about the heat transfer???to the inner fender
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
