nice job on that! great pics!!
Follow my Tweet (Twitter)
I think its a little different, some things were done differently than what I have seen, but looks like it works
I think you would see gain with the ports forward too, but would probably sound better ports facing back, and low end will stay stronger with the ports facing back.
And the ports with 4" between them and the back wall, thats not being choked off, thats the port having an ability to load off a surface, just like the common term, CRX boxes, ports facing back against the wall subs up
Thanks guys, and I guess youre right...it isnt that chocked off or anything..meh
And here are a few vids, might take another today since I dont have a single decent one...my camera simply can't pick up much flex, but here they are...the first one's just a run-through of the setup (but I didnt show the amp :( )
Posted Image
Posted Image
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
that rear deck is hating life... lol
Thanks guys :)
And it takes it quite well, just if you have it up for a decent amount of time it starts getting smelly and just have to turn it down..:(
Team Tupperware
Just took a better vid since the weather's so nice today...came out a little better, one sec
Team Tupperware
Here it is:
Posted Image
Team Tupperware
Here it is:
Posted Image
fkng nice ass build and flex
2 18's Fi SSD All Options Dual 2 ohm
Rockford Fosgate T20001 Bd
1/0 gauge Knukonceptz power wire
Pioneer Touch Screen Navigation AVIC F700
13.62 cu ft box ..28 hz
250 amp alternator
2 kinetik 2000 batteries
Xs Vcm Module
damn that thing looks violent
R.I.P!
(Nov-29-2009)
92 explorer
current build
