Looks sweet, Big power, wow....
2007 Great Wall So Cool
4-12' RE audio MX's
Stetsom 7k2D
6-Batts
3-Mechman 250 amp Rhino's
good shit broham
NoFearX18 said:
trainman0978 said:
I have used bolts before as a step down for small amp terminals. With a bolt you cut the head off use the threads to connect wire terminals and put the threadless end in the amps terminals. If you take a grinder and make a flat spot on the threadless end and it won't turn on you in the amp, it makes the amps terminal screw kinda like a set screw, just another idea.
It's all gone!
The Celica Build
Feedback
If I buy something from you, DO NOT USE FEDEX!
more pics of the amp(s)
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • 1 month later...
This is gonna be so sick!
PM me if u need anything for the van....I just happen to have one of those sitting around W/no tranny
Keep us posted!
Posted Image
My 93 chevy truck Orion HCCA 15's Build
6K HID's
2 orion HCCA 15.4
2 AP30001D's
2 optima yellowtops, 2 C&D 270fr's, all 3 tsunami 1/0, CS144 190 amp
Rockford p200-2
Rockford p200-2
Rockford p300-1
Kole KX1 5500D -broken
