Subsonic Filters
bennett15
My box is tuned to 33hz and sub is 18" SSD i know it can play
low rite now have my ssf set at about 20hz the highest my ssf goes on my amp is 35hz
and the lowest is 15hz should i bump it up to just inder 33hz or leave it? Also i have my highpass
set right around 45hz where should that be set to for best output?
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
HPF is personal preference.
I prefer 80Hz for HPF.
Most people usually set SSF 10Hz below box tuning.
I'd leave it at 20hz.
I'm going to assume that with the HPF or (subsonic filter) the amp doesn't just cut it off with a flat slope? If that's the case that would be great where it's at because it will give it a smooth slope down below 20.
MECP_SMALL.jpgCERTIFIED BITCHES!!!
Not being new at something doesn't mean anything. Just because a prostitute isn't new at what she does, doesn't change the fact that she still 'sucks'
Click to see my build!
Proud DC owner
Subsonic = HPF on a sub amp.
The other crossover is the LPF or LOW pass filter, as in beLOW this number can pass this filter.
Probably set your HPF (subsonic) to about 30hz and your LPF to ~80hz
10.x volts fo' life!
But wouldn't that keep his sub from performing at it's best since his box is tuned to 33hz?
I would guess that if the subsonic was set at 30hz then it's got a rollup slope that cuts right into the 33hz the box is tuned at which wouldn't allow the sub to get it's max power at that frequency and therefore cause the box to not perform at it's peak. If it was possible I would try and set the low pass at around 25hz.
I might be wrong, just my guess on the matter.
Proud DC owner
no, if set at 30hz.... it likely does a flat drop of 3db at 30hz or at 29.99hz it begins to drop... then follows the slope of the hpf(subsonic)
so if set at 30hz (box tuned to 33hz) w/24db slope.... at 22.5hz it would be -12db and 15hz it would be -24db
5-10hz below tuning is fine... as long as u dont play bass i love u, put on... bubble up... or a few others u dont need to get lower than 30hz...
Ah, I see, so it's more common for the slope to be flat then.
I was thinking it was more of a curve.
Proud DC owner
