Would it be possible to hook up a full DJ System in a car? Lets say.....an altima...? :01nocomment8so:
Just want to know if it could work. I had a temp dj system in my explorer running off an inverter. Just want to know if its possible. Thanks :]
haha pimp my ride did it once.
its very possible. idk how to do it tho
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Yup it's easy enough (with money, haha), seen it done on a couple of cars here, mostly trucks with the decks mounted on the tailgate so the DJ could stand behind it and mix...
Edited by Boon
10.x volts fo' life!
im talking about dj speakers and amps also.
would you need to run seperate invertors?
Why not just run your dj speakers wit regular audio amps.
Vehicle: 2001 Ford Escape
Head Unit: Kenwood Kdc-x592
All out for a rebuild.
New shit coming in the next 30 days.
There would be a significant advantage to run your speakers of regular DC car audio amps.
All amps use DC current, so your dj amps have a converter which takes the AC from your wall puts out a DC current for the amp.
When you use those in your car you are converting the DC from the battery to AC through the invertors, then BACK to DC inside your amps through the converter.
This results in a huge loss in power. If you are thinking of seriously making a permenant car setup i would recommend using car audio amps.
you couldnt get an inverter big enough to run GOOD p.a amps
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
so run....for example...my aq amp to my rcf dj equipment? but....would i run that with my sub rca's or my regualr front/rear input rca's?
  • Who's Online   0 Members, 0 Anonymous, 1613 Guests (See full list)
