Whats up Everybody
Friday a good friend of mine sold me a pair of JL 12W3 D4's he had in his Explorer. They sounded great when he had'em hooked up, So I had some interest in'em. I figured I could use these until I get the cash I needed for what I really want.
Well on the way home I stopped at the store to get some things and I come to find my 2 1/2 yr old pushing in the dust caps on one of the subs. At first I was pissed seeing my lil' boy damageing my sub but I cant really hit him. Hitting my boy isnt gonna fix my sub, beside's, I got the subs & box for $50. Not trying to brag or nothing, but I had to jump on the deal.
So now I'm wondering about 3 things:
1) try to fix the sub? (but how?)
2) find another 12w3d4 to replace the damaged one?
or
3) Salvage the good sub and get another enclosure for a single 12 and ditch the old box & damaged sub?
Any replies would be great
Daniel
best luck i've had/seen is the same concept as pullin dents from a car body: either use something very TACKY like some high tack tape/fly paper or a very small suction cup if the effected area is flat & smooth enough for it to seal/grab.
I'd try some tape/double sided tape or similar tacky material to try to pull it out w/ out doing more damage.
good luck.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
Ive fixed dustcaps before, all I did was make a tiny hole with a pin, then bend the tip of the pin to make a 90 degree angle so you can stick it in there and pull it right up. A paperclip would work better for a plastic dustcap like those W3's though. Then just dab some clear superglue on the whole and youre set!
(Next time take the kid in the store with ya though)
B)
EDIT: this is if the sticky paper doesnt work
Edited by Chris
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
Yup.
Same as I was saying about it being just like autobody repair^^^.
Like using a screw-tipped-dent puller. The autobody version usually hooks on the end of a slide hammer so you can jerk the dent out w/ help from the weight of the "slide".
The downside is having to make that hole and then how visible it'd be afterward.
Try the sticky/no hole method first and if that doesn't work you can try the other way and might invest in a hook/pick set which have L's and "?"hooks you can get in behind the dent and pull with. The paper clips are generally too pliable and will just unbend/straighten out under pressure unless it's a thin paper dustcap (pretty sure it's thicker vinyl on a JL sub)
Try it with a good vacuum cleaner.
Worked for me 2 times.
Gr Herrie
Bingo. ;)
basicly if pulling it out doesnt fix it then as long as it play decent keep it. (doesn't play at all....ditch it or sell it!!!)
To Slide Sideways Or Not To Slide Sideways?
Head unit: Pioneer AVH-5000DVDSpeakers: 4 Pionner TS-G6842R Amplifier: Alpine MRD-300Subwoofers: 10" JL
hot glue and popsickle stick pull out dent and reheat with heat gun.
heh i never thought of that. i will have to try that.
RF Punch 40x2RF Punch 100x2RF Punch 200x2RF Punch 200x2RF Punch 400x4JL Audio 10W7-3"but its only a 200 watt amp tho"
