Setting Amplifier Gain Control
dbwesz
  • 2 months later...
  • 2 months later...
  • 2 months later...
i was just playing with my amp (t20001bd) and please correct me if i'm wrong. i turned the freq. on the amp down and all the other eq settings for the sub is flat. do i get the target voltage from there? when i turn up the freq. on the amp. the a/c voltage also goes up. oh btw. i don't have my sub hooked up and i was playing a 43 hertz tone and also tried it on 46. i was just wondering if i set it at the amp freq at zero then turn it back to about 80 when i'm done or set the gain with the voltage at 80?
  • 1 month later...
Or you can also set it "by ear"
I recommend doing it using a DMM but I have done many systems by ear in the passed and none have failed.
When setting the gains ''by ear'' you still need to use a ''50 hz tone'' to set it.....? and how would I set it.....?
by ear, you turn the volume up to about 75%. adjust the gain till you hear it start to get distorted. it's easy to tell when this happens. it just sounds kinda flat. then turn it back down a bit till it's a clean signal again.
  • 3 weeks later...
