Retracted Not! Another 150+ System
no offence but I dont see that breaking a 150 sealed on the dash on the TL150 is a tough number in a trunk car
None taken, and yes 150 is very rough to get. USACi is at kick though not dash. And like said my mic may be off, we'll see he was barley showin just over 150 like 150.3 if remeber right. I'm going to change amp out of his ride to a Massive d5000 I think that will be a good match with the subs he's runnin. Also still have to get some batts in for him. All good things come with time.
Team Soundstream
Team Optima
Team HK
2 Soundstream SPLX-152HX
2 Soundtsream TRX2000D
1 Soundstream RUB4.600
4 Soundstream SST65
4 Soundstream TWS.3
1 Soundstream S-Cell400
1 Soundstream Power Plant
1 Soundstream BX-15
1 VMAX CT1900
2 Optima Yellow Top D34/78
1 Kenwood KDC-X493
out of mine I got a 147.7 @43hz sundown 3k at 1/2 ohm and some beat up mojo 12s that was sealed on the dash tho Im sure with a bit of testing I could of been real close to the 150 in the kick
What is the port area. looks way to small. specially if your lookin for 150+
Here is the specs for box. The peak freq in his car is 49hz that is what I found and tuned new box to that.
Posted Image
Posted Image
Team Soundstream
Team Optima
Team HK
4 Soundstream SST65
4 Soundstream TWS.3
1 Soundstream BX-15
1 VMAX CT1900
1 Kenwood KDC-X493
ninja edit.. 150.3 at the kick on a tl? I'm not sure how much of a difference it usually is between the kick and dash.. anyone?
The difference is usually anywhere from 2-4 db from the dash to the kick. Also in Usaci they can have the door wide open and fan it which is going to add a db or two in itself as well.
On another note my team captain used to have a Cavy and it was the world's loudest trunk Cavy. He was able to do a 153 on the dash sealed out of the trunk with the seat up on 12 volts at 43hz!!! That's right I said on 12 volts with the seat up! He did over a 156 in the kick. The equiptment used were two DD9515's a pair of Stetsom 7kd's and some NSB 90's.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
That is true you can fan, but we do not it's BS.
Team Soundstream
Team Optima
Team HK
4 Soundstream SST65
4 Soundstream TWS.3
1 Soundstream BX-15
1 VMAX CT1900
1 Kenwood KDC-X493
that port looks tiny but looks like it would daily nicely 150 i doubt it but it looks like a loud daily non the less
R.I.P!
(Nov-29-2009)
92 explorer
current build
Thanks here's some more:
A little electricity: (The ground was a bad pic but showing that after attaching to body added a littl solder to conduct better)
Posted Image
Posted Image
UGGHHH Did no one else Notice the Wet Battery inside the car and the Ground that is screwed down with multiple screws then solder slopped on top of it?
Wow you said the other install was not up to YOUR Standards but THIS is? Wow Sorry but that is plain wrong man.
