does anybody kno if its possible to fit a 10-12 cubic feet box in a trunk of a crown vic or grand marquis or caprice,or if i can build one where my back seat is firing forward with a little bit of it in the trunk,will that effect the sound?
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
In order to get 10 - 12 cubes you are definately gonna have to do exactly like what you said and take out the back seat. Youre probably gonna have to cut some metal so that the box can go back into the trunk. Either that or wall it off. Any of the 3 have huge trunks, but not enough for that big of a box. What do you wanna put in there, 4 12"s?
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
crown vics have major cancellation issues and air transfer issues..... If you want a big box i would highly highly recommend making a port go through the rear deck aimed off the rear glass and seal off the trunk - i think you will be happiest this way.
1st place circuit city car/spl show (maplewood,MN) 2006
146.6 dB's with 2 12" L7 and 1606d brutus
yea i figured that,i dont wanna wall it thats why i was askin bout bringing it into the trunk,but the box bein smaller in the back wont effect the sound,i dont wanna wall it i want them firing forward
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
i have a crown vic, and i do have a 9 cu ft enclosure in it ( i cut out the rear deck) the whole trunk is a box and then the port is where the deck used to be..... (one solo x 12, soon to be 2 12" solo x's)
9 cubes for 1 12"?
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
How bad is noise cancellation in an older Cadillac? About the same I'm guessing but like cut 2 holes in the rear deck and make it look clean and that will solve it?
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
Only time you would have "bad cancellation problems" in that kind of setup is if you have a relatively SMALL box in an otherwise HUGE trunk and THEN try to get that sound/pressure that's 1)confined 2) allowed to reverberate/bounce around in the trunk BEFORE it finds a way out (rear deck/seats), to have waves crashing into each other in equal/opposite directions and thus = cancellation. Any time you generate more than one wave and in multiple directions you run the risk of them colliding and causing cancellation.
If you point the subs forward (behind the seats pointed towards interior of car) or up through the rear deck and seal the front wave off from the trunk completley, not only will you not have cancellation but it will be louder, and have little to no trunk rattle as all the pressure is relieved in the interior cabin rather than just shaking the big flat trunk lid which is where you would otherwise lose MUCHO bass. Flat panels are more succeptabel to flex than cureved ones and generally have big time surface area that pressure can cause to flex..flex=lose of pressure, loss of pressure =less bass.
Easiest example of how to do a trunk car...copy Steve's FIRST build of the civic before it was stolen. 2-18's ported forward and sealed off from the trunk='d mucho bass inside and no trunk rattle.
COOGLE SAID:"bro thats how we got where we are... buy making messes ...... i still learn all the time you just gota be willing to ruck up some shit" "In order to attain the impossible, one must attempt the absurd." ~ Miguel de Unamuno"One machine can do the work of fifty ordinary men, but no machine can do the work of one extraordinary man" -Elbert Hubbard"A proud man can learn humility...but he will be proud of that too" ~I forget who.I'm far from perfect and I know it better than anyone, but I hope to be good at what I do, when I do it...Installs I've done:My Integra: http://www.stevemeadedesigns.com/board/ind...?showtopic=3161The Lexus : http://www.stevemeadedesigns.com/board/ind...?showtopic=1535Law's Maxima: http://www.stevemeadedesigns.com/board/ind...ic=5568&hl=Jeff's 2500HD: http://www.stevemeadedesigns.com/board/ind...ic=5382&hl=Acura RSX-S: http://www.stevemeadedesigns.com/board/ind...?showtopic=3142Z-32 300zx: http://www.stevemeadedesigns.com/board/ind...?showtopic=34602004 Civic 4dr: http://www.stevemeadedesigns.com/board/ind...?showtopic=8190Trunk/Corner Box: http://www.stevemeadedesigns.com/board/ind...c=16036&hl=1969 Chevy C-10: http://www.stevemeadedesigns.com/board/ind...c=20319&hl=Seat-Back AMP-RACK How-to: http://www.stevemeadedesigns.com/board/ind...ic=9428&hl=Bunch of subs still for salehttp://www.stevemeadedesigns.com/board/ind...l=lsn2meboom916"It's game night...we're playin......sex."~Quagmire"When disneyland started it was powered completely by orphan children running on treadmills to generate e-lectrissty…and today, them children are New York Yankees". ~Dale Gribble"Fill it with ice...then pour it up to the top of the ice...& Shut da Fu** up!" ~Urs truly.
i got a grand marquis. im about to Cut Out some metal going from the back seat to the trunk. becuz the seats cant fold down. then im guna make it so i can have a seat over the hole then wen no one is back there pull it off. all my subs r in the back seat right now tho cuz my trunk is busted and wont seal. makes the subs sound wayyyy less loud. i wish my trunk was fixed :(
Gota have my rear view shakin and my seats vibratin'.
(2) 12" Diamond D3
(1) DEI Directed Audio 2400D
(1) Kicker L5 15"
(1) Rockford Fosgate P5002
(2) 12" Fosgate P2's
(2) 15" Fosgate P2
^^Not all hooked up at once, i rotate. Its all i got.^^
  • Who's Online   1 Member, 0 Anonymous, 636 Guests (See full list)
