earthquake has been known to produce power hungry dirty amps bro. Im willing to bet that is it. What load do you haev to the amp? If its 1 ohm or even lower then Id be more willing to bet on that. Id be really curious to see what the current draw is rated at and what its actually consuming.
i second this...
i had a Earthquake PHO-5000... and i didn't like it one bit.
I had retarded power drainage at 2ohms on my thunder mtx 7500's... needless to say i sold it and bought a different amp. I bought an AQ2200, and the drainage i got from the earthquake at 2ohms i was getting less at 1ohm on the AQ... but my case might be different, so idk
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
yea man i dont think one batt in the back would suffice...im late on this but what happened to your T4k?
Eclipse cd7000
Chode,
Your voltage drop actually seems normal.
The earthquake amp can draw as much as 400A of current so can the rockford amp. Your 300A alty is capable of less amperage when you increase your voltage, so you are exceeding what the alty can do and sucking juice from the batts, which like to rest at 12.65v.
You should worry unless you go below 12v but if you wanna stay a bit higher. You can add some batteries and keep them fully charged and keep the alty voltage just at 15 or below.
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
Chode,
This is very true as I have personally seen two different brand alt's drop amperage as the voltage was increased on the bench. But Robbie's ( DC Power) alts were doing rated power at higher voltage and off coarse increased amperage when voltage was dropped, so I think Rob rates his alts at higher voltage.
We had a similar voltage issue that was fixed when the belt slip issue was resolved. So I really do believe that Chode is have issues due to his belt slipping.
Random vids of the Avalanche My link
Team Bass-Hz
Clamp that amp and see wat she doin
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
your voltage fluctuates a lot without any bass...
don't mean to state the obvious.
hope you get it fixed I would hate to see such a great product do so bad http://www.stevemeadedesigns.com/board/public/style_emoticons/default/dirol.gif
actually i was touching the gas for a quick blip...thats when it jumps up to 15.6 ro 15.6 then down to 14.7...it i dont touch the gas it will stay at 15.1-15.3
im thinkin batteries, i have stock 130 amp, 0 gauge, no mla and 3 extra batteries, i dont dip that low at full tilt....should be good once you get another battery or two
i know i need another battery plan on another 2400 here as soon as i buld up some more bnak....but i still shouldnt dip THAT low on an amp of thsat size you know....
Is the rear buss bar still grounded the same?
I think you should use the frame
havent done that yet...havent round a way to get around it...im scared to drill through the floor either ima go in the wong place and end up in a bad spot if i do it fron under and if i do it on top i bet ima hit a gas line...
1 ohm
holy chit!!! im gonna blame it on the gay ass song :D
whoa whoa whoa...watch yoself...im on a boat mothafucka..dont you EVER forget...
Chode,
ooo ok Ed...but i still see people with less than me power supply wise...and same power draw and stay in the 13s on idol...im just like WTF...
and Chubby Chaser...(sorry i got tired of quoting)
it messed up again...mainly from vibrations...so im just gonna get rid of it all together...also im taking that D3 out..got something new comming in next week ;)
NoFearX18 said:
trainman0978 said:
i got my swim trunks and my flippy floppys
REST IN PARADISE BIG RICH (Sqmonte) never forgotten
Why do you guys ALWAYS dispute on NUMBERS?????
It's such a played out argument, so fucking annoying....
It's 12 fuckin 15's.... It's louder than you... Shut the fuck up...
/Rant
I'm so jealous, it makes me want to club baby seals. That shit gets down HARD!
dont buy from knowledge he will scam you.
http://www.stevemeadedesigns.com/board/topic/30995-official-knowledge-feedback/
HAHAAH thats my favorite part :D
that and
"FUCK TREES I CLIMB BUOYS MOTHAFUCKA"
NoFearX18 said:
trainman0978 said:
