K I got 4 powerbass m12s and I have em all inverted(vid comin soon)....I jus wanted to know if I wer to turn em around would it make a difference ???
92 Black Acura Vigor (Blacura)
pioneer head unit
powerbass s-series 6 1/2 components in front
2 stock tweets up on the dash
2 stock 1 inch speakers by the front dome light
alpine spg-17c2 6/12s in the back,custom fiberglass pods for them
hifonics MX-3 sound processor/line driver
BIG 3 done
stock alt...not for long
1/0G all around
optima yellowtop up front
kinetik 2400 in the back
Powerbass XA3000d sub amp
2 MTX 9500 12s, single 4 ohm vc
(so only doing about 2200w)
8awg wire for the subs
You have more space inside your enclosure with them inverted; but, other than that, virtually no difference.
You may hear a little noise from the pole vent with them inverted though.
in all the builds ive done thusfar, ive run inverted to save enclosure space, and when your trying to jam 18's in 4 cu. ft., if you run them normal you get like 3.8 per sub, it can really make a difference.
DCAUDIO
BALLS DEEP
how is it less cone area? sure you have the little bit where the cone mounts to the spider not on the outside of the box but it is now internal? so isn't it just a shift in where the cone area is? Hmm... ive never actually thought about that before...
seems to me it would be the same amount of cone area, just switch of what part is inside the box, and what is outside
1990 Jeep Cherokee 4X4
Pioneer DEH-P2900MP, Big 3 done in 1/0, 1 run 1/0 ran to amp
DAT HF1000.1 #007 powering a DC lvl4 15
DAT HR 4085 prototype powering 2 Selenium 6s and 2 no name tweeters running active
1st place in AS3 @ Surf City Sound Off, 140.8 @ 45hz @ the headrest.
rebuild coming soon to get a better score :)
"I regard the brain as a computer which will stop working when its components fail. There is no heaven of afterlife for broken down computers; that is a fairy story for people who are afraid of the dark."
this.
i think because of this reason it should be alil louder, depending on how big the back side of your sub is.
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
  • Who's Online   0 Members, 0 Anonymous, 752 Guests (See full list)
