Im about to get my build going and i need to know if anyone found a really good but cheap sound deadening material? I Need to do the trunk, headliner, floor, firewall, and also the hood. If its not good with heat then i dont have to do hood. I know its a hard question to answer but how much would i need to do a 2000 cavalier coupe?
2010 Silverado
18" DC XL 18
DC 2k
XS Power Batts
good question... ive heard people say peel and seal from home depot but it takes like 4 layers.... so it may not end up being cheap... idk... whoever has some knowledge on sound deadening... tell us our options... i was wondering about sutuff like truck bed liner and rubberized undercoating.... what can we do?
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
I like the second skin Damplifier Pro.
Is works best with heat because it doesnt soften and peel off.
Also, there are score lines in the foil backing that allows air bubbles to escape when being applied, assuring that it adheres to the sheet metal properly.
Using peel and seal or cheap deadener will almost certainly make sure it peels off in the summer.
Second Skin is better but less expensive than Dynamat.
They also make a sludge that works pretty good.
www.seconskinaudio.com
Ed Lester
ShowtimeSPL Host
Showtime Electronics Video Marketing
My old Build Log
http://www.stevemead...08/#entry511451
http://www.youtube.com/showtimespl
5 time dB Drag Finalist
Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music
New Ride, 2008 HHR SS. Build under way.
Loudest score ever = 171dB
2009 dB Drag Racing, North American Points Champion
I used Dynamat, HOWEVER, I also used the rubberized Spray from walmart. It's like $1.99 a can. Another little trick is Campers tape, It's sold at auto zone and it'll seal ur car up real good, just go around the doors/windows where it meets the weather stripping.
EDIT: sonicelectronix.com Is where I get my dynamat is actually pretty cheap.
Edited by b_smiff
HU: JVC Arsenal AR880
Subs: (4) Incriminator Audio Warden 15s
Highs: (12)Eminator 8s (12)Eminator 6.5s (12)Eminence Apt80s
Amps: (2) Incriminator Audio 40.1s (subs), (2) MB Quart Discus 4125s, (1) MB Quart 4.80
Electrical:
-DB Electrical 275 amp Ohio Gen
-BIG III
-(5) XS Power d3100s
152.3 In Street Beat 5.
State record in Alabama. (USACI)
http://www.youtube.com/Itgetslow
remaat
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
Edead is NOT a good find. It sucks. Second Skin just came out with a third line of Deadner that is for "inexpensive" needs. I would defiantly buy it.
  • Who's Online   1 Member, 0 Anonymous, 518 Guests (See full list)
