Reason Why My Amp Went Up In Smoke?
bennett15
i vote faulty wiring...alllthough a budget oriented amp they are still pretty solid if you dont abuse them..
07 mote carlo..
deh-p800prs hu-cdt gold 6.5's-cdt 6x9 2 ways-mcintosh mc431m(mids/highs)
bxi2608,2 10w7's in 4rth order(designed by pete k)ported into cabin via armrest cutout
dc power 260 amp alt-missing link module (15.4v)kicker 1/0 kit deka intimidator under hood
metered 141.0 @ 32hz windows down @ kick,termlab
i have to say faulty wiring sumwhere in the set up but just take it sumwhere and let them look at it and they possibly tell what went wrong.
I know a lil about everything so dont call me Mr. Know it All.
I bet if you crack it open most of your fets are gone. I've had a few hifonics brutus amps do that to me.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
^^^ so since u ran tons of amps retartedly they should all be able to take it?
I had a 1958 mote carlo and rammed it into a wall and it still ran, think i should do the same with my cobalt?
are you sure u wired the sub correctly? i could be wrong but i just did all the coil configurations for a single sub in both dual and quad 4,2,1 and not one could be wired at 2 and 1(1.4/.7)
so if it was actually at 1.4 before it was either... dual 4 so the only other rewire would be 8, dual 1(.7) able to be .5(.35), quad 2 able to be .5(.35) and 8
Actually what i said was I haven't had many amps, Not that I had tons. And actually I do think a 1 ohm stable amp should play at .7 ohms if it isn't flea market quality. I don't think that is why his amp blew up.
how could box rise make it over 1ohms when the sub wasnt even playing in the first place? im just wondering.
imo the amp blew cause of going below 1ohms.
'99 Civic hatch
18" AA Chaos - 7cuft @ 34hz - 114sq in. port
Mac Audio Fearless ~ 1000wrms @ 2 Ohms
Videos:
Youtube
noob+crappy equipment= poof!
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
You do relize that when you wire a sub to 1ohm its actaully .7ohm right.....he didn't go below 1ohm.....
1ohm coils = .7
2ohm coils = 1.4
Vehicle: 1997 S10 Blazer 4dr 4X4
Exterior: Rear End Bagged, Black Grill, Lifted 2"
Amplifiers: Rockford Fosgate T8004 & T10001bd
Batteries: 2 Stinger SPV35, Kinetik HC2400
Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v
Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube)
Headunit: Eclipse CD3200 w/ 80G iPod
Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors)
Subwoofers: 1 15" Fi BL Fully Loaded
Wire: All 1/0g Kicker Hyperflex
My YouTube Videos
My Fiberglass A-Pillar Build
My "Seamless" Looking Box Build
My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer)
My Stealth 8" Fiberglass Build (for '05 TrailBlazer)
My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk
My feedback/references...
i agree with you on that part a 1 ohm amp should be able to play 1 ohms nominal (.7ohm is 1ohm nominal as is 1.4 2 ohms nominal) but not half an ohm.
i still have yet to see a wiring configuration for a single sub that can be both 2 and 1 ohms
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
I have an awfully sneaky feeling that the sub is a Dual 1 and he had it wired down to 0.5 ohms... if you measure a 0.5 ohm load with a multimeter you'll often get around 0.7 ohms read because of the resistance of your test leads combined with inaccuracy of most multimeters when reading that low.
My Fluke reads a 0.5 ohm load as 0.7 ohms, I know my test leads have 0.2 ohms of resistance :)
10.x volts fo' life!
sub is D2 when i put the leads of the dmm in the sub
its reads 2.0 on each then if i wire it up to 2 ohm and
put the dmm leads on the sub it reads 1.8? then when i put
the leads of the dmm on the wires going to the amp i get a 1.4 reading.
if i do the same but to 1 ohm then check wire going to amp with dmm it reads
.7? sub is still sitting at 2.0 at each coil so its fine.
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
  • Who's Online   0 Members, 0 Anonymous, 1555 Guests (See full list)
