Bigger Box?
What are some of the effects of having abox that is too big for a sub? I know it lowers the power handling of the sub but is there anything else to be weary of?
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
surely somebody knows if there are any other drawbacks of a bigger box.
you will gain some spl.
Club 150 (15x.x)
Youtube
Future Build:
1x 15" T3 TSNS
2x Sundown Audio SAZ3000d Parellel strapped
well i made a box that was suposed to be 9 cubes, 6 cubes, and now it sounds like im bumpin pyles. last time i take advice from someone on smd <.< lol.
but yeah, aslong as you modify the port too, you will have better SPL qualities.
im taking out my passenger seat, battery is disconnected, going to unwire and take out the three amps, take out the 70+ lb box, then the platform so i can crimp 1 wire.
Almost as bad as those fegs that put those horns in their grills and roll down the street distorting the block....
1990 Jeep Cherokee 2 Dr.
Big-3 in 0g on Stock Alt.
Pioneer 6.5" and 5.25"s temp. until i can afford the new crescendos.
Pioneer 6000ub Reciever
NO amps at the moment. SA-15 on 1kw coming soon.
MSG Me for a free enclosure design!!
Flared port kits coming soon!!
I would definitely think that there is a point at which box size becomes too big that the returns greatly diminish (some folks may disagree). Power applied, volume of the box, and port area all go hand in hand with each other. In my experience, the reason Mr. Meade does not blow subs left and right (other than the fact his subs are quite nice and he knows how to properly set the gain) is because he uses minimal port area and minimal overall net volume. This decreases the efficiency of the box, but it enables him to throw an assload of power on those subs without worrying a whole lot about their health. The amount of resistance inside Meade's box actually helps with controlling the cone. Increasing box size and port area raises the efficiency, but you will definitely decrease the ability to apply huge amounts of power. If my technical assertions are wrong, I definitely encourage someone to correct my statements. These are conclusions that I have not only read on the forums, but have come to for myself as I have built enclosures over the past 7-8 years.
1999 2 Door Chevy Tahoe 5.7L V8
K&N Cold Air Intake
Kenwood KDC-BT555U
1 Clarion EQS746 Equalizer
1 Clarion MCD360 Crossover
4 Incriminator Audio 1st Gen Warden 18's - 4th Order Bandpass Wall
4 Incriminator Audio 40.1s
8 PRV Audio 8MB450 8" Mid-Range Drivers
8 PRV Audio 6MB200 6" Mid-Range Drivers
1 Stetsom 3K3ES
8 PRV Audio TW350Ti Titanium Bullet Super Tweeter
1 NVX JAD800.4
2 XS Power XP2000s
8 XS Power XP3000s
10 sets of Team Project DB BA60 Battery Terminals
3 Mechman 270 amp alternators
GETTIN LOUDER DAILY!
bigger box+bigger port = bigger power handeling. not much, but a little. and if its recomemded 4 cu.ft. per sub, dont go like 5+ unless you know that 4 is under-rated, or if its a hella good sub. just dumbed down from above
word. bigger boxes tend to gain on low end response, but you lose a lil on the high end response, and vice versa with smaller boxes.
Well I just built a new console box for my aq 15 hdc3. It is 5.33 cubes with 93 sq in of port. When I talked to dj at audioque he said it was a good bit too big. He said he doesn't normally recommend but about 4 cubes for those subs. I had my aq1200 running at 1/2 ohm with the old box(3.96 cubes with not nearly enough port) and the sub never had any problems. When I get everything hooked back up I'm thinking bout wiring the sub to 2 ohms to be easier on electrical and the amp as long as there isn't a significant loss in output. What do you guys think?
I'd say run the amp at 2 and .5 and see which is better fits your tastes. If at .5 ohms it isn't too much louder, I'd say go for 2 ohms for the reasons you stated.
Good luck,
Larson
  • Who's Online   0 Members, 1 Anonymous, 8773 Guests (See full list)
