I dont know if this has been discussed, but i just found out that one of my subs was halfway out of the box *2 18" hdc3's walled*
Wondering how the hell this happened i noticed that 3 of the bottom screws are still in the box and the screw seems to have gone right through the entire hole of the basket.
i use the gold plate screws... just a tad thicker than drywall screws... how big of a screw can i go? or what does everyone else run... i feel like a noob right now.
I use 5/16ths t-nuts, with 5/16 bolts on my BL's. Before this, I was using screws, and everyweek I had a dancing speaker
I love my staffie :good:
So anti FACEBOOK it isn't even funny
I use these http://www.parts-express.com/pe/showdetl.c...tnumber=260-778
97 Maxima SE
Bunch of shit going in, check out the build
I use the same thing but mine are chrome and 1/4" x 2" in size.
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
I use big wood screws, holds 2 of mine upside down just fine :)
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
i dont know how much bigger i can fit through this sub... i kinda like the T-nut idea tho
T Nuts are great if you take the subs out a lot, I find screws to be a better option if you leave them in the box.
Subs: 4 Fi BL 18's
The reason you bust screws is because you don't torque them. For those who have been here a while and seen, I've installed 88 subs in my car alone since joining the forum, 16 of which were upside down (EDIT: firing down) and I've never busted a screw head.
If you try to make them extremely tight or don't support the weight until you have all four sides with at least one screw, you'll pop em.
Torque them and you'll be fine.
Edited by Neo_frog
Need an install? Hit me up.
[email protected]
  • Who's Online   0 Members, 0 Anonymous, 3227 Guests (See full list)
