I just ran out and looked at the back and thought and measured and figured this is better. The port runs down 11in. port and sub face up.
A MAN WHAT PROGRAM DID YOU USE TO GET THAT MEASUREMENT>>> LOOKIN TO TRYIN OUT A NEW ONE
he wouldnt be the first to say they did a 167 with a system like that (one that clearly DOESNT), but i have to say, he didnt beat me anywhere, ive never competed against the guy. If he thinks his does a 167, mine would probably put him in a coma. :hairtrick:
?? no, even with the use of a slot port, i get a length of about 35" for the tuning to be at around 32 hz.
yeah sorry about that reran the numbers and came up with 34in length 32.04 hz the 18in length will give you 38.29 hz but i did not take into account any bracing just the sub im using bass box pro 6 for the record
Edited by Jville140db
Car is 2010 Scion Tc
Currently in car
Deck- Sony XAV-60 in-dash mobile video system
Speakers- Rockford Punch 6.5in comps in the front and coax in the rear
Subs- 2 Gen 3 Rockford P3 12's dual 4 ohm
Amps- Rockford P1000-1bd and P400-4 Alpine Mrp-f300 is in for P400-4 which is out to service
Wiring- all rockford nuff said
Enclosure- Dual 12in custom box by SRQ
Battery- Optima Yellow top with big 3 done
Sound Damping- All Dynamat products 1-2 layers throughout with liner on top
Link to my build log- http://down4sound.co...=newpost&t=5275
Link to my youtube- http://www.youtube.c...ser/Jville140db
MECP Advanced CEA # 110531
BassBox 6 Pro for Box Building/Re audio box calculator
If you can hear the passenger it aint loud enough!!!!!!!
QUOTE (MickyMcD @ Sep 25 2009, 07:25 PM) "My system has 30 speaker terminals, that means shits wanging doggggg....."<!--QuoteEnd--></div>
I don't understand... I run these damn numbers 100 times and I get what I am looking for and you run them and get something way off from me...getting aggrivated
Two different programs... two completely different calculation methods I'd assume.
RF T1000-1bdCP and T400-4
Boston Acoustics SPG 555
Kenwood eXcelon 995
bass box pro hasn't let me down yet very reliable program what are you using or are you doing it by hand
Currently in car
I got one off the forums and 3 off of google searches
ahh so what programs are they
Currently in car
I even used your calculator and that's what I got. Then I used one from Alpine and theirs said like 19.5. So my results from the two were 18" and 19.5"
your height and width are in the wrong spots. you need to switch them. if you're using a slot port with 22.5" from the box wall to port wall, it's adding in 11.25" for end correction. when in fact it should be 4" for height, adding in 2" for end correction
it's mine. it's in my sig
switch the height with the width and you should be good ;)
even so, the end result should be the same if the formula was executed correctly. seeing as how he had his numbers switched, i think they're both ok really :)
