I was curious as to what type of fuse holders ppl were using because i have to buy one every couple months due to the fact that my shit keeps melting...i have 2 1200 watt amps (2400watts max pull) running off of a 4 gauge... ANY SUGGESTIONS?
Edited by 8000watts
bigger wire if they are true 1200w amps.
DC.jpgDC POWER
X20
upgrade to a single 1/0 for power and ground see if that helps.
put a 300 amp fuse on that 1/0
X20
do they only come in that waffle style?
I'm guessing Power Acoustik or Kole.....by what he says they put out and his username.
Edited by wL<3bass
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
if it's true 2400wrms you're lucky you haven't had the 4 gauge catch fire
Current Systems:
2011 BMW 335i
Hertz HDP1
DC LVL3 12" Full Carbon Fiber
2002 Acura Tl
Kenwood DNX9980HD
2 DCLVL4 12" Subs with LVL5 Parts D.7 Coils
DC 3.5k
Hertz HSK-165 up front HCX-165 Rear
Hertz HDP4 Amp
DC Power Engineering 260 Amp Alt
Big 3 and amp powered with KNU 1/0
XS Power D2400 Up Front
i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch...
going over rms = smaller box, under rms = bigger box...
Low voltage doesn't blow amps. That's a myth.
A router that does the sub holes makes rounded edges also?
can you tell us what these so called amps are? 2400rms off of a long run of 4 gauge = heat = meltdown
i use 4 gauge on my mids and highs amp
NOT RMS...THEYRE BOTH 1200 max...doubt if my bass amp is n e where near that max with rms(sony xplod)...oh and do u have seperate wires running for each amP???
  • Who's Online   0 Members, 0 Anonymous, 3517 Guests (See full list)
