Mechman Alternators
Um... so i think i broke something
But i noticed my radio had reset itself like it does when i disconnect the battery. but i didnt. i only disconnected the alt.
when your wrench hit the pos on the alt the short probably made the voltage drop low enough to reset the hu.
"Audio is not a hobby it's a lifestyle"
_____________________________Refs_1_Refs_2_____________________________
I did alot of demoing today. and when i get it up to full tilt they squealin goes crazy. then i was drivin home on the highway, just about full tilt. i look and my dash and notice teh speedo lights are dim, look at my voltage. its like 12.3 turn the music down, squealin like crazy. so i turn the music off and it doesnt stop squealin. finally i hear a kinda thump and no more squeal. but my lights are still dim. my voltage is down under 12volts. so im thinkin shit i think my belt fell off. i get home, look under the hood and no belt. i think im gonna go to oriellys and get on of the gates belts tomorrow. and charge my batts too. side note about my demos. ppl hear me from far way :-)
Whoops. Thats gotta suck losing a brand new belt.
yea. but its just more money i gotta spend now.. hah
the worst part about it is puttin it on. the nut to tighten for tension is in a tight spot, and i always end up with a scratched up arm.
i miss the bass already though.
Just in case the oreillys guys give you trouble this is how you shop for a smaller gates belt
This is the stock part # for alt+ac belt
K060439
K06 stands for 6 rib belt
the 439 stand for 43.9 inch belt
Team Sundown
Team XS Power
System:
Car: 1997 Honda Accord
Head unit: Alpine CDE-7870
Amp: 2 Sundown saz-1500
Battery: kinetik 1400 and 2400
Subs: 2 Audioque HD310 D2
Just so you know when you work on a car, disconnect the ground on the battery first.....
If you want, we can "de-tune" that alternator some so that it doesn't slip the belt so bad.
Unfortunately, your vehicle has a pretty bogus belt setup from the factory, it just can't grip a really strong alternator.
Also, if you keep your batteries on a good charger overnight, it will make the alternator's job easier during the day, just FYI.
I was just about to email you about this stuff. Wat exactly does de-tune do?
also more troubles today. I go shoppin for the gates belt. first i get a 5 rib instead of 6 then i get a six rib thats not green strip. but it was too small. then i get a longer green stripe and got it to fit. i turn the car on. still squealin and stayin at 13 volts. so i turn of the car and tighten it up some more. start up the car. a slight squeak. then its still at 13 volts. i can hear it starting to spin faster and faster and my voltage is goin up and up. and stops at 14.5. my brother and a girl holdin the light are standin there watchin. im thinkin yes.. its fixed. i turn the car off and all the sudden smoke starts comin out of the alt.?? so i wait turn it back on wait a little bit. it looks like there is smoke in the air, but its hard to see. i also got a temp gun and the inside was about 350F?? i turned the car back off and again smoke starts coming out. I can smell somethin, but it doenst smell like an electrical fire.
any idea wats up now?? is it somethin as easy as teh belt being too tight? Also i had the batteries on a charger before i turned the car on. i didnt check the voltage before i turned the car on, but aftewards when i checked the were at 13.3v
