Using a ring terminal will work fine. If this is for a Tahoe (I'm guessing because of your name) then I recommend switching to a dual post battery. Use the side posts for your stock wiring and the top post to add on for you system.
I have to look at my battery. I'm not sure if it's top or side post. They may have changed it in 2007.
It's top mount. I took some pics and I don't have a clue where to run this wire. Can anyone help me. I'd kinda like to get past this stage. Also, there is a compartment near headlight on the driver's side that looks like a battery can go there.
This is the area I was talking about.
Yeah, you can have a dual battery setup! this will save you time & money in the long run.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
I'd just use the battery that you have & use a ring terminal. All you gotta do now is find a place to run you're wire back.
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
So put the stock battery in that area and put another battery where my stock one is?
Oh no, you can just leave that other spot empty for now. Keep the battery you have where it is now connected and everything, just find a place to run your power wire back to your amp and hook it up to the batt by soldering or crimping a ring terminal on. What size wire are you running?
1- T1000.1bd's
4 runs of 1/0 gauge
-Big 3
All in a CAR.
0 gauge
if your just gonna do dual batteries, keep the factory one in its spot and put your kinetik, optima etc... in the other spot since your system will draw from it first. also you might want to consider using an isolator if your gonna run the system with the engine off so your not drawing from the factory battery as the second one is draining.
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
  • Who's Online   0 Members, 0 Anonymous, 4497 Guests (See full list)
