but what will be also the best for an hair trick with an wall
big or small, low or high freq ??
Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps
with some other worths i needs to go LOW en hairtrick able like that im already going low but i want a lil louder and lower
and what do you guys think about 7000 watt each mt for just daily using ?? will that be alright??
or is that 2 much power ?
7000watts is too much for daily...i believe steve had about 4000watts per sub when he had his mt's, and i think he smoked a few subs (not sure if it was b/c the wattage or some other defect)..but i wouldnt even think of putting 7000watts on each mt for daily.
i likes me some audio stuff...
but i think u can imaging that im not 24/7 playing max volume ;) cause when im playing while driving i always play low volume only on meetings couple of times a lil louder
and i heard here in this forum many times the mt's just awake with 3500 watts
Edited by dbwesz
so lets get on port area a little bit
port area im not too sure on, I think you increase port area to allow air to escape quicker, thats why it larger port areas work better in spl.
then im rambo bitch
aero ports are the real deal. I paid about $50 for the ports for my box and it's worth every penny. It is a different kind of sound..... more impact, sharper compared to my old slot port - and it's clearly louder or the same as port, i think it's a lot louder, but who knows - what sounds loud isn't always what is loud on a meter
1st place circuit city car/spl show (maplewood,MN) 2006
146.6 dB's with 2 12" L7 and 1606d brutus
the reason its louder is because it is more than likely tuned closer to your cars resonant frequency. I guarantee you that if you have a slot port and an aero port with the same area and exact same smoothness, they will sound identical
then im rambo bitch
