finkster Posted July 17, 2009 Report Posted July 17, 2009 i have a 93 dodge stealth. has never seen above 13.5 volts since ive had it. i think my alt is bad. the battery is about 5 yrs old but always stays at 12, so i dont think thats it. anything else i should look for? Looks like im spending tomorrows paycheck on a mechman lol.... PS i have no system in right now either. also at idle if i try to turn the car will shut off... DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
AI James Posted July 17, 2009 Report Posted July 17, 2009 some cars are just like that. my friends celica neve see's over 13.5 ever with 2 xs power batts and system off even. and never did on stock elec either
Boon Posted July 17, 2009 Report Posted July 17, 2009 some cars are just like that. my friends celica neve see's over 13.5 ever with 2 xs power batts and system off even. and never did on stock elec either Ouch. I dare say those batteries aren't even getting a proper charge. 10.x volts fo' life!
finkster Posted July 17, 2009 Author Report Posted July 17, 2009 Thanks for the replies. As it turns out, James you are correct. Most stealths are lucky to even see above 13.3 when the car is warmed up. As for my car stalling, I think my IAC is shot, so im gonna clean it today and see if i cant idle smoother. Im gonna bet its gooked up. Im looking into getting an MLA module but would the extra voltage hurt the car if its only used to seeing low 13s? maybe thats a dumb question, i dont know but i do know that my amps wont like it if they only see 13-12 volt its whole life DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
cqtama Posted July 17, 2009 Report Posted July 17, 2009 just to be sure try starting your car and then disconect your battery ground. if the alternator is good the car will keep running if its bad your car will stall. its always good to double check R.I.P '01 blazer you treated my ears well until your transmission blew up. New Project [top secret] 149.0 db on music driver window open; so close I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean.... I swear... sometimes I wish I was retarded so I could just agree with everyone x.
sully Posted July 17, 2009 Report Posted July 17, 2009 your car will be fine up to around 16 volts so the MLA will help you 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
MECHMAN Posted July 17, 2009 Report Posted July 17, 2009 just to be sure try starting your car and then disconect your battery ground. if the alternator is good the car will keep running if its bad your car will stall. its always good to double check Not a good idea- This will damage some types of alternators. The easiest way to know if the alternator is functioning is to take simple voltage measurement. The batteries chould rest around 12.8 volts if it is a standard flooded battery, or 13.1 volts if it is AGM type. If the voltage increases when the vehicle is started, the alternator is functioning. If you want to determine how much amperage is being produced by the alternator, you will need a DC amp clamp meter. (see Dom's sticky at the top of the page) 1-888-MECHMAN www.Mechman.com [email protected]
finkster Posted July 17, 2009 Author Report Posted July 17, 2009 Not a good idea-This will damage some types of alternators. The easiest way to know if the alternator is functioning is to take simple voltage measurement. The batteries chould rest around 12.8 volts if it is a standard flooded battery, or 13.1 volts if it is AGM type. If the voltage increases when the vehicle is started, the alternator is functioning. If you want to determine how much amperage is being produced by the alternator, you will need a DC amp clamp meter. (see Dom's sticky at the top of the page) thanks alot mechman. it wont matter too much longer because ill be purchasing an alt from u this paycheck anyhow lol. another update. I cleaned the IAC and it seems to be running better for now. DAT 4125------>RE XXX comps active Eclipse cd7000 I serve drunks for a living
