I was wondering if you've tested th sax1200d, I'm putting it to 2-sa12's...
IIRC it did rated power with a rise to 2 ohms, or something along those lines. It was in a thread a while back, possibly the thread Jacob started when it first came out.
Edit: I found the thread. Here's Jacob's quote:
Two Stinger SPV-70 Batteries / 40-amp Power Supply / 8 awg wire power and Ground (this amp should have 4 awg)
Wired to 1 ohm nominal :
1170 Watts @ 12.5 volts
1.97 ohms after impedance rise
Wired to 0.5 ohm nominal :
1490 Watts @ 11.1 volts
0.85 ohms after impedance rise
Measured with my Extech True RMS power clamp meter several seconds into the tone @ 60 Hz -- this typically reads about ~15-16% less than a "dual peak hold" amp clamp test.
We'll do some more testing with a more adequate power wire coming up soon. The test bench 4 awg has the ends tinned so is a bit too big to go into the SAX-1200D terminals -- will need to get it in a vehicle.
Edited by R_Mac_1
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
Thanks guys! So it should do fine with 2sa12's until I jump to the 1500d
anybody measure the amp draw of a 3500d anywhere from .5 ohm to 2 ohm?
I don't fuck around. I go from zero to I hope you die in less than 2 posts
build log http://www.stevemeadedesigns.com/board/topic/104524-new-subs-coming-sundown-3500d-arc-audio-cable-lacing-crescendo/
ah, how did you come up with a power figure for one of those amps if you didn't measure thee output voltage or current?
your tests seems rather flawed to me.
I'm pretty sure I know how to clamp amps :drink40:
In any event -- this is the meter :
http://www.extech.com/instruments/product.asp?catid=14&prodid=109
When compared to traditionally utilized separate meters this meter reads lower 99% of the time as the meter captures the actual power at any given moment. Separate readings can have a time variance; especially dual peak-hold which can be drastically off.
- Jacob Fuller
- Owner, Sundown Audio
- Sundown Audio on FACEBOOK
- Please DO NOT PM ME -- use my email address -- [email protected]
  • Who's Online   0 Members, 0 Anonymous, 828 Guests (See full list)
