I've always loved sundown and thinking about running 2 18s in a ridiculously low tuned box. How would the 18 nightshades like 28-30 hz?
If I'm not mistaken most every 18 inch woofer is made with the intentions of Deep Bass.....Don't see why SD would be any different.
I mean sure you could tune your box for your 18's to be more musical then just a deep note hitter (My Burban) but most people buy 18's because they get low.... :8)
Yeah some woofers just handle lower notes better. I have no idea what mechanical aspect of the sub its based on, but each sub is definitley unique. Kind of general to say 18s are made to "get low", but I feel you. Can't hurt to see if anyone else is running these in a box tuned to 28-30sh.
you have to remeber its 90%box 10% equipment
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
^^^what he said (tho i go 80%/20% :)) but if the box is tuned right...yes they will. mine is tuned to 35-36 hz and they play them just fine. if you build it...bass will come :D
usually the mass of an 18" cone lowers the Fs enough that low notes are very prominent when compared to the same speaker in a smaller size
nightshades have a pretty stiff suspension so i doubt u need to tune that low, iirc 34hz is a good note.... so 32hz at the lowest maybe
but the box will ultimately dictate what notes the subs responds best too
I think its more like 75% knowing what to do and 25% box and equipment....
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
Two NightShade 18s playing Gorilla Zoe - Waddle screwed version peaking @ 31hz. Is that low enough for you?
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350">
Just a little fyi. All Sundown subwoofers play the lows just fine. Even the little Sa-12s will get loud & low down in the 20hz range.
Its not that I need to tune it that low, I want to tune it that low. Thanks for the vid derrick good looking out. I guess Ill tune it to 28 and see how they like it.
  • Who's Online   0 Members, 0 Anonymous, 1611 Guests (See full list)
