SPL Question Ported Vs Sealed
Hotdog
Ok I have 2 Punch Power DVC 15" Subs that I just got and they came in a sealed box. now I know that Ported boxes get louder then sealed boxes but the question is...
assuming that both are being powered by a T10001bd and the subs are wired to 1ohm.. amp is rated at 1000+ watts at 1ohm
How much more will the Ported box get on the TL meter then the Sealed box?
it all depends on the ported box design, the car, and the cars resonant frequency. Could be anywhere from 1 db to 15 db gain.
Michael Hughes = 6X SPL World Champion - Loudest on the planet in db Drag, USACi, and IASCA.
My vehicles resonant frequency is 48hz and if I was to port it I would port it at 36hz
I would tune it around 40-41 then if your fs is 48.
My ported box with 12's in it is tuned at 33hz and when I had it metered it peaked at 48hz... So I assume that my vehicle's Resonant frequency is 48hz is that correct?
that's incorrect. different box frequencies will peak at different frequencies. there's a method to figuring out your cars resonant frequency. i dont remember it all in detail, lemme try to search for a thread on it real quick
EDIT: ok me and search dont get along too well. hopefully someone will post it up tho for ya
as long as you had doors / windows sealed up and there was no crazy amount of bass boost or equalization anywhere than that will be your resonant frequency. (or atleast within 1 or 2 cycles)
To test the fs from you're car, you need a sealed box, some test tones, and a TL or a other db-meter.
Just play test tones, and the highest db you get on freq.?? is the fs from your car.
that is what i have said for a long time. different boxes and tuning will change your peak hz...
m_8e0e9deb0e2a020a7ff1bf0d3a6c3306.jpgth_140x100square.jpgth_140x100rev2animated.gifsoundigital.pngth_Banner_140x100.jpgn221468318568_2854.jpg
  • Who's Online   0 Members, 0 Anonymous, 1989 Guests (See full list)
