dirtboi22 Posted August 5, 2009 Author Report Share Posted August 5, 2009 it can be 1 or 4 depending on wether you hook the coils up in parallel or series so how do i hook it up to one ohm? and is running my sub on 1ohm hard on it? Quote Link to comment Share on other sites More sharing options...
DGold Posted August 5, 2009 Report Share Posted August 5, 2009 The ohm load is a way to control how much output you get from your amp. The ohm on the coils is just so you have different wiring options. If you use too low of an ohm load it will hurt your amp, not so much your subs unless your amp is putting out dirty signals. Then you could potentially hurt both the amp and the subs in return for a little extra power and a voided warranty if you had one to begin with. Quote Old Setup 03 DurangoRF Power T1 6.5 CompsMids/Highs Amp: AQ4x90Sub Amp: AQ 3500.1DSubs: 2 DC XL 18sBox: 12ft^3 tuned to 33HzMechman 270 Amp AltXS 6500XS 3100 x2 Highest Score to date: 151.2 db @ Headrest Link to comment Share on other sites More sharing options...
dirtboi22 Posted August 5, 2009 Author Report Share Posted August 5, 2009 ok, so what is the lowest i can wire my 2 dual 2ohm woofers? wouldnt it be 2 ohm? Quote Link to comment Share on other sites More sharing options...
R_Mac_1 Posted August 5, 2009 Report Share Posted August 5, 2009 ok, so what is the lowest i can wire my 2 dual 2ohm woofers? wouldnt it be 2 ohm? You can wire each sub to one ohm (parallel) and then either parallel the two subs for .5 ohms or run them in series for a 2 ohm load. You could also run each sub in series to get 4 ohms each, then parallel them to get the 2 ohm load as well. But the lowest you can wire them would be .5 ohms. Quote 2002 Pontiac Bonneville SSEi Pioneer DEH-P6000UB Alpine SPX-17REF 6.5" components (active) Sundown SAX-50.4 Sundown z15 (3 cubes @ 35 hz) Sundown SAX-1200D 2006 Buick Rainier CXL AWD V8 Stock Bose system 12" Alpine Type E in aeroported box Profile AP1000M Link to comment Share on other sites More sharing options...
dirtboi22 Posted August 5, 2009 Author Report Share Posted August 5, 2009 jezz this is confusing! lol, so if i hook up one side of the sub for both subs it would be a 1 ohm load? Quote Link to comment Share on other sites More sharing options...
95_1500 Posted August 5, 2009 Report Share Posted August 5, 2009 jezz this is confusing! lol, so if i hook up one side of the sub for both subs it would be a 1 ohm load? If you have the speaker leads in parallel at the amp yes lol.. But each sub will only take half its power.. ie a 1000wrms dvc sub can handle 1000 with both voice coils hooked up, if only one is hooked up it can only take 500, or half the power.. Quote Original Build http://www.stevemeadedesigns.com/board/index.php?showtopic=24095 Link to comment Share on other sites More sharing options...
dirtboi22 Posted August 5, 2009 Author Report Share Posted August 5, 2009 You can wire each sub to one ohm (parallel) and then either parallel the two subs for .5 ohms or run them in series for a 2 ohm load. You could also run each sub in series to get 4 ohms each, then parallel them to get the 2 ohm load as well. But the lowest you can wire them would be .5 ohms. how do i hook it up in parrellel? to get a two ohm load Quote Link to comment Share on other sites More sharing options...
Torres Posted August 5, 2009 Report Share Posted August 5, 2009 no, hooking it up in parallel would give you a .5 ohm load. hooking it up in series would give you 8 ohms. what you're gonna need is a parallel/series combo like this: Quote Link to comment Share on other sites More sharing options...
shainemcconnell Posted August 5, 2009 Report Share Posted August 5, 2009 (edited) do not only hook up one coil...on each sub....Not a good thing. follow Exposport's pic post for all (well a lot) of your wiring needs http://www.the12volt.com/caraudio/woofer_c...sp?Q=2&I=22 Edited August 5, 2009 by shainemcconnell Quote 2010 IDBL Rookie 1 North American Champion 2009 IDBL Rookie 1 Fl State Champion 2009 EBB Fly Weight 3rd Place Fl State Finals 2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup. Team Pure Pressure Link to comment Share on other sites More sharing options...
dirtboi22 Posted August 6, 2009 Author Report Share Posted August 6, 2009 no, hooking it up in parallel would give you a .5 ohm load. hooking it up in series would give you 8 ohms. what you're gonna need is a parallel/series combo like this: thanks alot man you helped me out big time! but i got one more question lol i have two 2ohm re sx 15's, rms is 1000 on each, so if i hook my subs up this way( which i am) will i need and amp that puts out 2000 rms at 2ohm, or just 1000rms at 2ohm so they are both getting 1000 each? Quote Link to comment Share on other sites More sharing options...
