BigPimpin91 Posted October 3, 2011 Author Report Posted October 3, 2011 3000watts at 120% distortion... FTW!!! Haha Probably, but until someone makes an amp that does the same power for the price I bought mine at, I'll take it. Just read through the thread...Not quite sure how wiring amps works yet, but would this amp put out good power (not too much) for a DC Level 4 15"? And would I need to bridge (this doubles wattage output, correct?) if I decided to add another Level 4 15" in the future? And should I wire to 1Ohm or 2Ohms? A few questions, but I'm new to amplifiers. Thanks for any help with this, I was considering this amp from what I've heard about it being decent for the price. It will more than power your LV4. I'd recommend only running one side until you get the second 15". The amp is 2 1500's Internally strapped. You can either run 1 15 per side, or bridge it @ 2Ω. Either way will work. You can't bridge a monoblock amp, and no that amp isn't stable at 1ohm. 2 ohms is where it makes it's power, dirty, but power non the less It's two monoblocks in one case, so yes you CAN "bridge" it. It makes more power @ 1Ω. I ran both of mine at 1Ω each daily the only issue I had was thermal protect because they were mounted underneath my box. BigPimpin91's Banging Music
kam311 Posted October 3, 2011 Report Posted October 3, 2011 Well I would trust Jacob when he says he has never seen a .5ohm stable amp come from that build house. So if you run the 3k amp at 1ohm you would be running each amp internally at .5ohm... Maybe that's why you are going into protect. And if an amp is 2 boards internally strapped it's still not really "bridging" your amp for more power so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
BigPimpin91 Posted October 3, 2011 Author Report Posted October 3, 2011 Well I would trust Jacob when he says he has never seen a .5ohm stable amp come from that build house. So if you run the 3k amp at 1ohm you would be running each amp internally at .5ohm... Maybe that's why you are going into protect. And if an amp is 2 boards internally strapped it's still not really "bridging" your amp for more power I'm glad you follow the advice of others and don't do anything testing your own to come up with your own results. Jacob, is an intelligent man and knows his stuff, but he is wrong on this issue. I said thermal protect. Completely different. You can get them to do that wired at 4Ω if you manage to get them hot enough. With the amps mounted out from underneath the box, I have no more protect issues. As I've said about 28 times in this thread, I run both of mine @ 1Ω daily on music. Anywhere between 23 and 50hz and have no issues. We can argue the definition of bridged all day, but to someone who is needing help wiring up their amplifier, I will use the term bridged instead of saying, "use the two terminals on opposites sides of the amp." Bridged is much shorter and the point still gets across. BigPimpin91's Banging Music
splzx3 Posted October 3, 2011 Report Posted October 3, 2011 this is a lulz topic ________________________________________________________________________ deepsilencer, on 22 Aug 2011 - 17:32, said: splzx3, on 22 Aug 2011 - 17:27, said: i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD lol your mom is a G! WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
kam311 Posted October 3, 2011 Report Posted October 3, 2011 Well I would trust Jacob when he says he has never seen a .5ohm stable amp come from that build house. So if you run the 3k amp at 1ohm you would be running each amp internally at .5ohm... Maybe that's why you are going into protect. And if an amp is 2 boards internally strapped it's still not really "bridging" your amp for more power I'm glad you follow the advice of others and don't do anything testing your own to come up with your own results. Jacob, is an intelligent man and knows his stuff, but he is wrong on this issue. I said thermal protect. Completely different. You can get them to do that wired at 4Ω if you manage to get them hot enough. With the amps mounted out from underneath the box, I have no more protect issues. As I've said about 28 times in this thread, I run both of mine @ 1Ω daily on music. Anywhere between 23 and 50hz and have no issues. We can argue the definition of bridged all day, but to someone who is needing help wiring up their amplifier, I will use the term bridged instead of saying, "use the two terminals on opposites sides of the amp." Bridged is much shorter and the point still gets across. You're right, almost any amp would go into thermal protect being suffocated under a box, not just an audiopipe. And about running it at 1ohm, it goes back to what you are saying, I wouldn't recommend that a person asking for help on wiring an amp run an amp at .5ohm much less two amps at .5ohm a piece. I would at least suggest the he look into what electrical upgrades it would require before just assuming he will be getting that kind of power just by hooking it up to stock. I'm not trying to argue with you, I'm just saying it might be something to look at so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
BigPimpin91 Posted October 3, 2011 Author Report Posted October 3, 2011 You're right, almost any amp would go into thermal protect being suffocated under a box, not just an audiopipe. And about running it at 1ohm, it goes back to what you are saying, I wouldn't recommend that a person asking for help on wiring an amp run an amp at .5ohm much less two amps at .5ohm a piece. I would at least suggest the he look into what electrical upgrades it would require before just assuming he will be getting that kind of power just by hooking it up to stock. I'm not trying to argue with you, I'm just saying it might be something to look at You're absolutely correct. What works in my application may not work in someone else's. But to say that something isn't true, then there's an example proving it wrong, you have to look at the possibility of what you hold as truth to be wrong. No harm, no foul, bud. Just trying to learn some peoples is all. :drink40: BigPimpin91's Banging Music
kam311 Posted October 3, 2011 Report Posted October 3, 2011 True, I know there are people competing at a very high level with some audiopipe gear. But they are very knowledgeable people, more knowledgeable than most people in this lifestyle will ever hope to be. But it's not impossible that's for sure. And I learn things every day on here, so I feel that is good so far... HU- pioneer DEH-P59001B Amp- crescendo BC2000D Wire- 1/0 awg welding lead Electric- Big 3 ^same wire Subs- 2 Obsidian Audio 12 d4's Box 4ft^3 ported at 33hz. designed by Ram-Designs
Sergeant_Skyrim Posted October 3, 2011 Report Posted October 3, 2011 Thanks for the help, and while I know nothing about the electrical system yet (I am always more than happy to learn new things!), I was just thinking about possible future upgrades to what I've currently got. Nothing wrong with dreaming, hey? Build in progress
CleanSierra Posted October 3, 2011 Report Posted October 3, 2011 hella rise. ups will be dropping mine off monday ftw Yeah tell me about it. If Jacob will bring that trade in program back. A 3000D @ .5Ω will help with some of that rise. :hairtrick: Oh, and BTW, AudioPipe 3k's WILL NOT run @ .5Ω bridged, almost instant protect as soon as you turn it up. good to know you saved me some trouble im looking for a cheap amp that will do.5 daily....i know good luck.. You bumped a year and a half old thread? Nicely done Im not the one you want to try to troll. Just a fyi for you.
AI James Posted October 3, 2011 Report Posted October 3, 2011 so if someone bumps a old thread wanting to know more about the topic at hand they get crucified now, but normally i see 30 asshats telling someone to SEARCH. also ive had a few audiopipes with nowhere near the luck the OP has had..i wouldnt honestly recommend them to anyone i know considering i like to recommend quality to my friends and acquintances. A company that is so all over the place with build quality and output results ...no thank you.
