TeamHT Posted September 11, 2013 Report Posted September 11, 2013 Do you guys even understand what the fail is? That sub is STILL a D4 sub...nothing is changed. All the switch does is wire the sub in either series or parallel. There is no switch to change the sub from 2 ohm to 4ohm. When I wire my D1 in series or parallel...am I changing the coils? No. Tell me...does this smell like chloroform to you?
TeamHT Posted September 11, 2013 Report Posted September 11, 2013 AND even if you guys were paying attention to the information you guys are trying to post, then if the sub was a D2 wouldnt the switch go from 1 ohm to 4 ohm? If it were a D4 wouldnt it switch from 2 ohm or 8 ohm? How does you get a 2 ohm load or 4 ohm load from either a D2 or D4? Tell me...does this smell like chloroform to you?
TeamHT Posted September 11, 2013 Report Posted September 11, 2013 omg thanks for posting that kicker Thanks? Please read and learn Tell me...does this smell like chloroform to you?
justin0943 Posted September 11, 2013 Report Posted September 11, 2013 AND even if you guys were paying attention to the information you guys are trying to post, then if the sub was a D2 wouldnt the switch go from 1 ohm to 4 ohm? If it were a D4 wouldnt it switch from 2 ohm or 8 ohm? How does you get a 2 ohm load or 4 ohm load from either a D2 or D4? if you look at the pic its a 2dvc the switch is on 4ohm, flip the switch to 1ohm. same as the 4dvc flip it 8ohm flip it the other way 2ohm 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
justin0943 Posted September 11, 2013 Report Posted September 11, 2013 Thats actually a pretty good idea for people that dont know what they are doing. thats what I said much easier to the people that has no idea on what they are doing.if you can't flip a switch or don't know number you don't need it. 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
TeamHT Posted September 11, 2013 Report Posted September 11, 2013 AND even if you guys were paying attention to the information you guys are trying to post, then if the sub was a D2 wouldnt the switch go from 1 ohm to 4 ohm? If it were a D4 wouldnt it switch from 2 ohm or 8 ohm? How does you get a 2 ohm load or 4 ohm load from either a D2 or D4?if you look at the pic its a 2dvc the switch is on 4ohm, flip the switch to 1ohm. same as the 4dvc flip it 8ohm flip it the other way 2ohm It Isn't Switching. Its wiring series and then parallel. The sub is STILL a D2...is it really that difficult? Tell me...does this smell like chloroform to you?
TheMonolith2001 Posted September 11, 2013 Report Posted September 11, 2013 ^I think he is right, I remember seeing something like this before although I can't remember what brand it was or anything. Maybe a Polk? I just found this - Are you ready for some windshield cracking bass you guys? http://cincinnati.craigslist.org/ele/4047948438.html
justin0943 Posted September 11, 2013 Report Posted September 11, 2013 its still a switch no matter what it does 02 dodge ram 1500 reg cab 3rd gen 2 sundown sd-2 d4 soundstream rub1.2500 amp all sky high car audio-fuse,fuse holder,wire,ring lugs and rca flex tech box design by Joe X supension-mcgaughys 2in drop spindal ,western chassis 6in flip kit,buddy custom c-notch 04 5.7l hemi motor swap and made it an slt eletric everthing youtube channel-http://www.youtube.c...43?feature=mhee http://www.stevemeadedesigns.com/board/topic/190882-02-dodge-ram-1500-3rd-gen/
TeamHT Posted September 12, 2013 Report Posted September 12, 2013 No, it's a switch to switch the wiring. Now you're just failing, switching from series to parallel DOES NOT change the resistance of the coils. You can not be this blind to actual science. It's a switch...that goes from SERIES to PARALLEL. Case in point... Please tell me how a D2 or a D4 sub goes from 2 ohms to 4 ohms...point is you don't understand what the fail was (the coils do not change) and it's obvious you don't understand voicecoil configurations or are just ignoring science because you don't want to admit you are wrong. Either way...you're wrong Tell me...does this smell like chloroform to you?
DubNDodge Posted September 12, 2013 Report Posted September 12, 2013 No, it's a switch to switch the wiring. Now you're just failing, switching from series to parallel DOES NOT change the resistance of the coils. You can not be this blind to actual science. It's a switch...that goes from SERIES to PARALLEL. Case in point... Please tell me how a D2 or a D4 sub goes from 2 ohms to 4 ohms...point is you don't understand what the fail was (the coils do not change) and it's obvious you don't understand voicecoil configurations or are just ignoring science because you don't want to admit you are wrong. Either way...you're wrong Dude. That switch adds wire and cuts wire off of the coils to change the resistance. In just the flip of the switch. It's THAT good. '01 Dodge Stratass Sealed Trunk Build Log 2008 Honda Fit Sport Build Log On 10/3/2013 at 10:00 AM, ROLEXrifleman said: Anyone who says they knew everything they wanted out of life at 19 can go suck a bag of dicks cause they are lying to themselves or brought up in a cult.
