P4killer_ Posted August 17, 2009 Report Posted August 17, 2009 So im building in the back seat of my 2 door skylark and the floor of course is not very level. so ill need to build a stage of sorts to build a level enclosure on so it i can secure it properly. anyway so i just replaced my gas tank and looking below the car it looks as though the entire back seat area pretty much has the gas tank below it. any way i need i ideas for mounting 2x4's to the floor idk if something that would barely screw into the metal would work i could take pics if needed whatcha think thanks P4Killer. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
VistaV6 Posted August 17, 2009 Report Posted August 17, 2009 Maybe weld a metal rack instead of 2 x 4's??? Or maybe some godly glue? That's all I can think of. SUCCESS is a decision, NOT a dream. You have to name the price you are willing to pay to get it. "You didn't have an ice pick on you? Amateur. " -- Wax from Fchat.
P4killer_ Posted August 17, 2009 Author Report Posted August 17, 2009 sadly i am not a welder [tear] Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
tibs Posted August 17, 2009 Report Posted August 17, 2009 take the tank out and put bolts going up secure what ever it is down and put tank back in.. Tibs 99 F-150 Build 8 twelves 8 - Re SE 12"s 2 - SunDown Audio Saz-3000d's 1 - vx4004 planet audio amp big 3 1/0 gauge MECHMAN 250 amp alt MySpace
Boon Posted August 17, 2009 Report Posted August 17, 2009 Yeah either screw up from under or get some construction adhesive. 10.x volts fo' life!
Rogers Posted August 17, 2009 Report Posted August 17, 2009 i would say.. drop the tank and secure from underneath...... or find existing bolts and make brackets... thats how i made my amp rack.... i used the bolt holes that bolted the back seat in and made brackets for the false floor(if you will) http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
mr.p Posted August 17, 2009 Report Posted August 17, 2009 bond the 2x4's with mma based adhesive or a form of liquid nails. it WILL hold if your surface is clean. DCAUDIO BALLS DEEP
P4killer_ Posted August 17, 2009 Author Report Posted August 17, 2009 I will take another look see thanks for the help guys. Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
