Hobby's 2004 Silverado Ex Cab
I would of had a wall long ago but the wife won't let that happen,lol.
You dont need a wall. Your truck is crazy as it was.
Here is the new base and rack going together
MOAR!!!
R.I.P!
(Nov-29-2009)
92 explorer
current build
Looking bad ass! I just can't understand how you guys can do builds with this weather (outside that is). It's snowing, raining, and cold as hell up here. Maybe I'm just a wimp :P
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
I have a little heater in the shop. Worked on wiring in the cab all day today. No heat and snow on the ground. Its all torn up now and ready to go back together tomorrow hopefully.
All I have left as far as pictures is this.
The box is painted flat black
Then I tagged it
Then I started cutting out my door panels.
2 in each door. A Polk MM6501 6.5 driver on top and a DDW 6.5 on the bottom. Im going to run the DD's in sealed enclosures on the bottom of the doors. Should wind up .4 - .5 sealed if im lucky. Im leaving the A pillars and kicks alone. They work and sound good so im not messing with them. Might do some painting in a few places.
lookin good bro!!!
NoFearX18 said:
trainman0978 said:
  • Who's Online   1 Member, 0 Anonymous, 1738 Guests (See full list)
