Which amp(s) should I get?
26 members have voted
  1. 1. Running on 4 Optidrive 1232D Dual 2 ohm
    • 1 Lanzar Optidrive 6000D
      10
    • 2 Audiopipe AP30001D
      16
I need help choosing amp(s). The Opti will run me around a grand, the Audiopipes around 700ish. Opti has been proven, and the Audiopipes come pretty damn close to rated.
2 - Audiopipe AP30001Ds
1 - Lanzar Opti Scion 600.4
4 - Lanzar Optidrive 1232D's
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar Opti 6C midbass
1 - Alphasonic PCT6551
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
1 - AudioControl Epic160
by your signature I can see you're a dedicated Lanzar man but their products just aren't what they used to be. Honestly I wouldn't run either of those, but it's your money and your taste. I would think you would have a little more flexibility with the 2 AudioPipe's versus the 1 Lanzar. If nothing else you should be able to squeeze a little more out of the 2.
1990 Chevy Suburban (Big Booty Judy)
(4) Sundown Audio Zv5 18's
(1) Sundown Audio Salt 12K
(1) Sundown Audio SAX-100.4
(1) Sundown Audio SAE-50.4
(2) Crossfire ST-1 Tweeters
(2) Obsidian Audio ST-1 tweeters
(4) Sundown Audio Neo Pro v3 6.5's
Saving 2nd Bass
really depends on what type of subs do you have, you can wire the ap3000 at 2 ohms for 3000 rms or 2x 1ohm for 1500 per channel...
Team_DC-Derrick's Youtube
Team DC Audio
Since my subs are dual 2's, I can run them parallel/series for a final resistance of 2 ohms for a pair, x 2 pairs. Or I can run them each parallel at 1 ohms resistance, one sub per "channel" you could say for the audiopipes.
The Opti6000d, even though it's no longer the Zed build that I grew up with and loved, still puts out more than rated power.
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
Posted (edited)
you could go with the 2 amps for less imp rise so your subs will receive more power
but with 1 amp, you only have to worry once about setting gains... so its a toss up man.. but those APs draw alot of power and are beasts as well
Edited by Army_guy614
Team DC Audio
Posted (edited)
Errr...
More like 5500w @ 14.4v, maybe.
There's a guy running one on FloridaSPL, at 15.6 volts it's pushing 6800 watt rms, and TheDukey42 on ROE tested one.
I have the opti 6000D, had it benched for me & it put out 3500 rms @ 4 ohms. Was benched on 2 yellow tops, 1 up front & 1 in back. Did very well & was efficient.
Edit: After rise during the bench, it did the 3500 rms @ 5.1 ohms
I didn't have the 2 ohm & 1 ohm testings done because we had no subs that could take the power!
I am currently using it in my car w/ a 70 amp alternator, stock front battery & Kinetik 2400 in the trunk, I have a constant 14.5V reading at normal listening levels, when I turn it up I have a 13.5V reading, so for me that is not a bad dip at all, but I am not sure what a bad voltage drop is. I assume it's 12.5 or below.
Edited by lanman31337
1 - Lanzar Opti 5.1
1 - Lanzar Opti 6.1
1 - Lanzar VX830
1 - JBL 22 band EQ
1 - Lanzar SDBT75NU
id go with the opti, pretty much same amp at the soundstream xxx if i remember correctly. i never had an issue with the optis i had.
