All you have inside the wires for the neon are positive and negative. So all you need to do is get a 12v source for the hot(positive) and ground your negative to the body. There are a couple ways you can do this, one that involves purchasing a toggle switch, and one that does not. With a toggle switch, all you have to do is find a constant 12v source, t-tap onto that, wire your switch up, and your done. Tuck your wires and go. Without a switch you will have to find a switched 12v source like your ignition or accessory wire. You can also tap into a dome light or remote turn on, ect...
Hope that helps....
2001 Blazer
Pioneer 5900IB - (2) DC Level 3 10"s - Sundown 1500D
To hook up my neons under my dash i just went to the cigarette lighter opend up the casing and stripped a little bit of the rubber covering off on both positive and negative. Then i just wrapped the positive and negative of the neon tube to that. That way you can still use ur cigarette lighter and have your neons on at the same time. Has worked for me.
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
yea that would work great!!
QUESTION... is it possible to hook up your neon to an amp? or speakers?
lol.. just curious.. lol..
ummm im not really sure, it might cause static noise wen playing a song. But I just bought neons that go to the music anywase. I wouldnt recomend doing that though.
System Specs:
MTX Bass Knob
80 amp stinger fuse
Run arelay off of your remote wire send one wire to the amps the other to the neons. that will allow your neons to turn on with your stereo and not interfere with your tunz
Scientia est Vox
SMD SUPER BUYER/SELLER
  • Who's Online   1 Member, 0 Anonymous, 2302 Guests (See full list)
