Right i have got 2 lvl5 15's in a grand cherokee off about 4k between them.
I am just not hitting what i think it should be. To the ear it is hard, does hairtricks and people are noticibly impressed. The uk importer of these dc's has 2 lvl4's off 3k, hits 148.9 db drag, he heard mine and said that is a 150 car.
with lvl4's in here off about 2k it was just 142 peak.
I have only tested in a format i think only the uk has which is called propper droppers
the term lab is on the passenger headrest and you are allowed windows and doors open.
for me i hit my peak with both front windows open, it is noticibly louder and moves a lot of air with the front windows open so on db drag i think it would be even worse, i am getting about 2 or 3 db less iirc with car sealed but term lab on headrest.
i am doing very near to my peak score on music too, about .4 db off i think.
heres my scores
Peak= 146.8dB @ 37hz
40hz= 146.1dB
33hz= 145.0dB
25hz= 141.6dB
20hz= 137.3dB
as an example theres a guy with 1 15 mayhem off 3k hitting about 1 db more and about 4 more at 20hz
his box is tuned to 24 hz, mine is 32 but his peaks about the same freq as mine.
my box was designed by someone over here, it certainly moves lots of air and sounds good to me.
made from birch, big flared ports, glassed inside with matting and 45's on corners, 45 on bottom of port. m16 rod through box, its 2 chambers not a common chamber. subs up port up, no room for port back.
car is fully deadened all over, theres still a lot of flex with the rear window coming open by maybe a quarter inch. i tried pressing down on this during testing but made no difference.
I have heard cars which hit higher scores but they dont sound anywhere near as loud or hairtrick etc.
Is the jeep just a bad car for this? people over here say because its a big car its harder to hit high scores (most good scores are from smaller cars to be fair)
sorry for the long post but where am i going wrong?
well the box is tuned really low to put up a really high score i would also have to wonder what your voltage looks like and what kind of jeep that you have
TEAM NEMESIS
my system
1) us amps MD3D, us amps md21
2) kicker solo x 12 in 2.7ft^3 at 37hz
Meca scores
1 xxx12" 141.8db at 40hz,
1 18 rd alpha v.2 145 db at 38hz , 2 12 orion hp 144.9 at 43hz
Refs: hollatchaboy, schrummy, nitro_freak1,Brandon15zzz,Hellbound Train
Its an 04 jeep grand cherokee
the voltage is high 12's when booming and maybe low 13's on one of these propper droppers burps.
i,m using a soundstream xxx6500 at .7 ohm, its meant to do just over 4k at 13.5v so i,m basing the power i have stated on that.
I have 2 sundown 3000's about to go in so that may gain a bit i,m hoping. but still i was shocked at the high scores from 1 mayhem off 3k, the guy even admits mine sounds way louder to the ear and we are both confused.
More power your just teasing those subs. Tune higher or find out where your car peaks at then add a removable port. Ground pound daily and fart machine on comp days.
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
