sorry, :sorry: haven't seen it.
Damn it's just soo big, got to be really easy to put the sub in the enclosure. :D
Lolz, you have any idea of what it will do spl wise? Are you planning on running a pair of 3000d's or 3500d's? The vehicle is an Explorer still right? If you get a good 7K+ to it I'd say that you should be able to do 154's out of it.
running the SAZ 3000d Twins / Strapped @ 15v
Should be loud, but usually spl boxes are narrower. The face is just big enough to fit the sub on it so the lenth of the box forces all the pressure out of the ports. I understand if yours isn't because this is the only thing that would fit, sometimes we have to compromise when doing a build. Spl will probably be affected some, but this should be loud none the less.
Is this your first time using aeros? They're real aeros too, not the psp's so that should give you about a .1db increase right there. Good luck :) !!!!!!
How are psp's not real aero ports. :unknw: Do these not have flared ends? http://psp-inc.com/
lol last time I checked psp are real aero ports I have some .....and everyone I know uses psp ports.
Bass junkie for life!
99 eclipse under construction
91 AWD turbo talon under construction
98 extendedcab s-10 under construction
S W A T!
141.3 dash (97 sunfire)
140.3 kick (97 sunfire)
resin the rest of the surfaces on the inside looked like bottom was bare while sides were resined
aeroport is the brand right. Like crecent wrench even though it's a craftsmen.
Exactly.
An aeroport is a brand of flared port, so is a psp. The aeroports are proven to be louder than a psp hands down. Your getting a flared port confused with an aeroport as quite a few people do. A flared port is just that a flared port, Aeroports were made by Lightning Audio and are a type of flared port. Understand?
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
