DC Sound Lab
Well I had a single 12" DC lvl 4 XL in a tine running on a RF T1k. Now I have two 12" DC lvl 4 XL running on a DC PAI3K. New box is custom built, tuned to 33hz. 2.76³ ft per chamber With 2.44³ ft after displacement. Here is some pics..... I didn't have much mdf nor $$$ so i recycled an older box for the cause lol.
I use chrome hex head screws and t nuts to hold my subs in nice and tight.
Made a 1/2 way decent faceplate ... It completely seals the box from the trunk while still being somewhat removable lol. Its made of foam , mdf and roll on truck bed liner. My rubber surrounds got some foam on them so they look like ass now unfortunately. Ill get some new ones eventually. I'm also thinking the red section might look better as silver.
Here is my amps in the trunk. DC PAI3000.1 for the subs and RF 400.4 for the mids/highs.
Notice the single run of 4ga.. lol yeah not enough power. Need to upgrade to some 0ga or some 00ga. But for now I recently found some 4ga laying around in my basement so i put it to use. Ran 3 runs of 4ga from the battery up front to a distribution block in the back. I got a 5 foot piece of 0ga running from the distribution block to the DC PAI3000.1 IMHO its hella lot better/louder... seems like its getting its power now.
This is a video I made b4 I added the 2 other runs of 4ga and 5 foot of 0ga. So its under powered. I'll post some new videos tomorrow tho (Give it time to process)
name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>">
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>" type="application/x-shockwave-flash" width="425" height="350"> Edited by SojiaRaggs9000
* Eclipse CD3200 with PAC SWI-CAN2 and SW-ECL2 Steering Wheel Controls Interface
* Pioneer D-Series Mids and Highs ( Fronts: TS-D1702C; Rears; TS-D1702R and Dash; TS-D1002R )
* Rockford Fosgate PBR300X4 ( Mids and Highs Amp )
* DC 3.5k with Dual Inputs; Custom Plexiglass Backing ( Sub Amp )
* Rockford Fosgate Balanced Line Driver
* One FULLY LOADED ~ 10" DC m2 XL
* Custom Built Carpeted Ported Box Tuned to 32hz. Single Chamber With Volume of 1.44618³ ft ; 1.13216³ ft After Displacement
* Custom Built Carpeted Trunk Wall with Added Fans for Amplifier Cooling
* MechMan 240a High Output Alternator
* KnuKonceptz Krystal Kable RCA Cables
* Upgraded Electrical With 1/0 KnuKonceptz Kolossus Fleks Kable and 1/0 Sky High Car Audio Cable
* Five Exide Orbital ORB34M Marine 12 Volt Batteries
* PowerMaster XS D3100 12 Volt Battery
My 2008 Chrysler 300 Limited - SuperCharged 3.5L V6 - UBL
My Old 2005 Ford Taurus - CarDomain - Vehicle Was Sold
nice stuff there...get the power cord when you can...
03 GMC Sierra Z71 Ext Cab l 2 15" American Bass XO's l 1 Lanzar HTG2600 l AudioVox 1510D In dash DVD l KnuKonceptz Wiring l Big Three Done with KnuKonceptz KLMX 1/0 l Infinity Reference 6022si 6-1/2" Front Door Speakers l Upgraded to 145A Alt from 105A Alt l Custom Box 2^3 under the rear bench with resined bottom, and about 4 lbs of polyfill
how do ya like that DC amp so far? looks good and im a fan of recycling wood/boxes lol why not right :D
that opening in the box is smaller than the port itself. that's bottlenecking the port. i'd open that up (if you can now) to the same size as the port so it wont hinder performance
Will do, for now tho 3 runs of 4ga should be ok. Basicly like putting a bit larger than 0ga in. Need to get a battery for the back as well... all in good time I suppose lol.
That's a beefy ass box, nice ass subs and nice ass amp. How did you make the faceplate?
I used a jig saw lol....Basically it is sitting/attached to the front of the box. Foam was used to seal cracks and air leaks then I painted it all with Dupli-Color bed liner.
I love it, it treats me good. No problems as of yet :P
lol, yeah i noticed that myself when I took the pic... I put it on the inside insead of the outside of the wall... I took it apart and fixed it, kinda why there isn't any in between pictures lol.
Took a new vid... you can tell it seems to have more power 4 sure. Give it time to load up. :) Yeah I know... lol dang 110+ weather is making part of my tint to unravel.
