A big problem or not?
gti'snahoe
No expert, but would have to say not good.
Alpine CDA-9847 HU
F Highs 2x Infinity Kappa 60.9CS Powered by Eclipse EA4200 Glass door panels
R Highs Infinity Ref. 9622i powered by HU
3x RF Punch HX2 RFD2210 Powered by MTX Thunder 81000D
Box Vol. 3.259 before displacement, Tuned 36.6, Port area 54"
coil rubbing is very bad...unless u mean more of a smack..like the coil is hitting the back plate (as in bottoming out)..cause that aint so bad..
but if u push down on the sub and the coil rubs...that is def not good...
i likes me some audio stuff...
well i'm thinking about buying the hdc3 18 from ericr says it has a slight coil rub that you can hear only at really low volume and doesn't think it is a really big deal, so i was just looking for some other input
No coil rub means it's fucked. You'll eventually wear through the enamel on the wires, the voice coil will go short and your amp will let all the magic smoke out unless it has a really fast protection circuit ;o
EDIT: That's if it actually has coil rub. With a really tight gap like those subs have if you push down even slightly off-center it will rub.
10.x volts fo' life!
Get it and order a rcone.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
  • Who's Online   0 Members, 0 Anonymous, 13017 Guests (See full list)
