guys i need a lil help for a friends install, its gonna be 2 18s dc lvl4 xl, supported by two group 34 batteries and a xs d3100 in the rear. i know there are guys on here that had experience wid both amplifiers ne response appreciated!! sundown 3500 or 2 audioque 2200d?
Edited by dblovah51
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
Depends on the coil configuration of the subs honestly. If they are D1 or D4, I would run the Sundown Audio SAZ-3500D and if they are D2's then the Audioque 2200D's. You cant go wrong with Sundown's CS.... Edited by X2.H10.V4
well actually after we decide on the amp based the on positive feedbacks i get then ill know wat coil to get, whether dual 1s for the sundown or dual 2s for each audioque! based on power output of the amplifiers cas i have seen guys said they gain more from one saz3000 rather than 2 audioque 2200d!
2004 trailblazer
4 FI BTL 18s
(2) DC 10.0k
xs power d3100s
mechman 270
158.2 @41
well look at it like this.. AQ amps are solid and all buttt... they put out there rated power at 14.4V like there supposed to.. Sundown do over there rated power at 12V.. now choose.. :)
2007 Chevy HHR LT
UNDER CONSTRUCTION
1st Place Loud N Low 2010 MWSPL Finals
3rd Place Xtreme 3 2010 MWSPL Finals
AQs
Pioneer AVIC-N2
Ugh sundowns and AQ are both rated at the 14.4 volts testing voltage.
Sundown 3500 http://www.sundownaudio.com/index.php/prod.../saz-3500d.html
Audioque 2200 http://www.audioque.com/aq/AQamps2200D.htm
I also tested a SAZ-3000d vs one of my SPL Dynamics ext-3000ds, and the sundown made about 560 some clamped watts less then my spl (with voltage well above 14 volts wired at .75ohm, 1.5 ohm after rise).
Both are great amps however, Id go with whichever amp(s) you can get cheaper
AQ's if your on a budget.
Otherwise, Sundown.
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
I think the one Sundown Will be a more efficient and easier install for you then 2 AQ amps. You won't have to worry about fitting 2 amps and gain matching ;)
did not say the sundown wasnt rated at 14.4.. jus said it can do its power 12V ive seen it with my own eyes on a pretty fluke.. and question??? wat did ur voltage drop to in ur burp when u tested? i know it couldnt of been more than 14V ..if it didnt props to u :drunk:
2007 Chevy HHR LT
UNDER CONSTRUCTION
http://www.soundsolutionsaudio.com/forum/i...d-side-by-side/
hmmm
I know someone will ask these questions SO READ THIS FIRST :
1) AQ-3500D Tested First - Battery Bank had a charge for several hours from our bench power supplies
2) SAZ-3500D Tested Second - Only a few minutes behind the AQ-3500D Test
3) THIS IS WHY the 3500D had much more voltage drop, I had the entire surface charge gone from the batteries
4) Both amps set wide open to be apples to apples.
AQ-3500D POWER TEST:
http://www.sundownau...0D/CIMG2679.MOV
AQ-3500D VOLTAGE TEST:
http://www.sundownau...0D/CIMG2681.MOV
POWER : 2400 Watts
AMP VOLTAGE (measured) : 71 V
AMP CURRENT (calculated) : 33.8 A
ACTUAL IMPEDANCE (calculated) : 2.1 ohms
SUPPLY VOLTAGE : 14.22 V
SAZ-3500D POWER TEST:
http://www.sundownau...0D/CIMG2682.MOV
SAZ-3500D VOLTAGE TEST:
http://www.sundownau...0D/CIMG2684.MOV
POWER : 3020 Watts
AMP VOLTAGE (measured) : 77.2 V
AMP CURRENT (calculated) : 39.11 A
ACTUAL IMPEDANCE (calculated) : 1.97 ohms
SUPPLY VOLTAGE : 11.99 V
I know this is not the 2200 but just for comparsism purposes
Edited by Team Nemesis-DJ
