Big Papa Posted October 15, 2009 Report Posted October 15, 2009 I'm thinking of using some aero ports instead of a slot port and need to know how many to run. Box is 35W, 15H, and 28D. Looking for tuning of around 32-35hz. Also, should I run subs up port back, or subs back port back? 06 Taurass SE 1 PPI Pro104 MTX TC 4001D Amp 1.5 CU. at 34 hz After Christmas... 2 PPI Pro104's Audiopipe 1500D 3.4 CU. at 35 hz
DUBIE Posted October 15, 2009 Report Posted October 15, 2009 for which subs??..some people go with 2 6" aero ports..the bigger the port the better..if you get a small aero port you will some likely have port noise.. correct me if im wrong
Nightshade Posted October 15, 2009 Report Posted October 15, 2009 So are you trying to run around 7 cubes for a single 15 that is in your sig? If so I'd say you need to drop box volume for your first thing. I'll wait until you answer what equiptment you'll be using as far as sub, amp, and even the vehicle it's going in. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
Marlo Stanfield Posted October 15, 2009 Report Posted October 15, 2009 ^^ For the most part, yes you're correct. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
Twistedchild420 Posted October 15, 2009 Report Posted October 15, 2009 The box for my DD 9512 has around the same dimensions as the box you listed...that being the case use 1 6" aero with 10" flare.....that's what i did......fyi My POS Bass machine-2003 Hyundai Santa Fe on some shitty 22'sBed Liner Paint Job-Pioneer AVH 3200DVD4 DAD BD series 15's in a 4th Order (Bassheads ENT Design)4 Arc Audio XDI2000.1 for the woofers6 Cadence CVL68MBX 6.5's-Cadence CVL88MBX 8's-6 Cadence XT20 Supertweeters2 Arc Audio KS300.4's for mids and tweets1 Arc Audio ALD 10v Line DriverAll Audiotechnix Power wire1 DC Power 270XP High Output Alternator1 XS Power D3400 up front....6 XS Power D3100's in the rearAir Lift 1000 Bags in rear to help with suspensionIf your still reading this GFY.......
Big Papa Posted October 16, 2009 Author Report Posted October 16, 2009 So are you trying to run around 7 cubes for a single 15 that is in your sig? If so I'd say you need to drop box volume for your first thing. I'll wait until you answer what equiptment you'll be using as far as sub, amp, and even the vehicle it's going in. As I was desigining the box on RE's calc, I realized the port was alot of displacement. Thus the reason I asked about aero ports because I'm keepinf everything in the trunk. Anyone one wanna design me a 4-4.5 cu. box tuned to like 33hz with aero ports? haha 06 Taurass SE 1 PPI Pro104 MTX TC 4001D Amp 1.5 CU. at 34 hz After Christmas... 2 PPI Pro104's Audiopipe 1500D 3.4 CU. at 35 hz
Brandon15zzz Posted October 16, 2009 Report Posted October 16, 2009 big ports Vehicle: 1995 Impala SSHead Unit: Pioneer AVH-P4400BHMids And Highs: (still deciding)Batteries: 1 Deka Group 34 Time to make a race car.My Build Log: Solo X 12"http://www.stevemead...don15zzz-build/My Build Log: DC lvl 4 xl 15"http://www.stevemead...don15zzz-build-My Wall Build Log: 4 Lanzar 15's/ 3k+ RMShttp://www.stevemead...t-by-techforce/My Feedback:http://www.stevemead...1
audiofanaticz Posted October 16, 2009 Report Posted October 16, 2009 Just because a Aeroport is thinner plastic, vs a thicker 3/4 inch mdf for a port, doesnt really mean that the aero port is going to have less displacement. You have to remember that the displacement of the port is not only whatever the port is made of, but all the space inside the tube and or the slot port. Using aeroports dont require to have "as much" port volume vs a slot port, but you still need to be pretty close. For tuning and cut lengths goto their site for the aeroports and they have their own calc for port length http://www.psp-inc.com/tools.html
