I used to have an AMD 3200+ single core processor and had it over clocked with not problems, then i upgraded to a 939 mobo with a 3800+ X2 dual core AMD processor and tried to overclock to 2.4GHz (stock = 2.00), I had the voltage set at 1.375 Volts. Windows booted up fine and I could play games, but within about 10 min of playing a game, it would just freeze. cursor wouldnt move or anything, I was wondering if someone could tell me what the problem is. Until I find a solution I have set the Clock speed to default, same with voltage. Help please?
Damn Thiefs
its nearly impossible to overclock dual cores, sorry to tell you this
1986 C20 Suburban
9 American Bass XFL 15's
B2 M1MKII
14v XS Power Batteries
Maxwell Caps
Acoustical energy is free. Electrical energy is not
you havent lived until you've hit a screw with a router.
You can overclock dual cores, my buddys is oced to hell, altho I forget what his specs are.
Its probolly not your cpu, most likely your ram speed maybe maxing out, your ram timings maybe to fast, your cpu and or ram might not be getting enough juice, you may have your htt set to low or too high.
Its really hard to say. Overclocking takes time to get your computer too run stable.
Id deff say to flash to the newest bios version on your motherboard.
Id turn off the amd utilities such as aibooster or whatever if you have it.
Id turn off every setting in bios that is set to auto such as voltages, multipliers, and what not.
But it be better to know what motherboard, and ram you are using also.
You can overclock dual cores no problem. First thing you want to do is make sure you have a good heatsink. Try raising the voltage a bit more. Sounds like an overheat problem to me though. I used to get the same thing on my old pentium 4. I just added a Zalman 9500 and it worked perfect.
System Specs:
Alpine SWR-1542D 15" sub
Sealed Subwoofer Box
MTX mxa 6001 Class D 774watts RMS @ 2ohms
MTX Bass Knob
Pioneer 6.5's in doors
MTX Thunderdome 6x9 in rear
Stinger 1 Farad capacitor
80 amp stinger fuse
BIG 3 in 4 gauge wire
4 gauge power/ground wire
JVC MP3 CD Car Deck (KD-G320)
12 gauge Monster speaker wire to Sub
16 gauge Stinger speaker wire to doors
Stinger Gold Plated Battery Terminals
i overclocked my Quadcore 2.66 to 3.47 NO problem at all. Im watercooled though so its easier to keep the processor chillen'. Keeping that processor cool is probably the most important thing when it comes to overclocking.
Follow my Tweet (Twitter)
Pretty much is the most important thing when overclokcing. That and making sure u have enough voltage to the CPU.
System Specs:
MTX Bass Knob
80 amp stinger fuse
