No. Not unless it's for burps or possibly bassrace. (but I'm unsure of the bassrace part).
My comp setup (Not bad for what it is):
HP Compaq Presario V6120US laptop with:
15.4" widescreen
AMD Turion 64 X2 1.6GHz processor
2x1GB stick DDR2 SDRAM (667 Mhz)
Seagate Momentus 500GB SATA HDD
128MB shared video memory
Windows 7 Home Premium 64 bit
12 cell Lithium Ion battery (actual battery usage time: 6 hours)
What it does:
On a USB 2.0 Wireless card
No. Not for either. Do not run it at 0.5ohm ever.
Idk why but i just found this pretty funny how Derrick was so stern about it.
Pioneer AVIC-N2
maybe if you read the manual that cames with yours....
it states that it can not play below 1 ohm and can not have a voltage above 15 volts. i believe doing either can blow the amp or void the warranty.
Edited by J00bles
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
Didn't mean to come as rude about it. I understand it can get confusing for guys who here some of us brag about how all the Sundown saz series amps can play at 0.5ohm daily even though they're not rated or warrantied for it. The sae series amps will not though.
