Batcap 800 vs Kinetik 800
looking into getting a small battery to help out with voltage stabilization, i'm running about 1400rms total and i drop from 13.9-11.9 under full tilt.
I've already done bigIII, so i'm looking into different brands.
What difference am i going to notice between a batcap 800 and a high quality deep cycle like a kinetik or powermaster of equal rating?
longevity? performance? size? nothing?
i'm just curious and i have no background in this area, so i thought i would ask.
Any help is appreciated
Current Setup:
Factory HU with LOC
mids/highs-Insignia components
Sub- E8 in bass tube
Amp- sae-1200d
Show Setup:
HU-Sony MEX-1HD (brings massive respect for sony)
fronts - Infinity Kappa perfect comps
rears- Infinity Kappa coax
mid/high amp - Autotek 5600
Subs - 2 RE SE 15's
Sub Amps - 2xSAE-1200D
Box - 5cubes sealed
Wire- Lots of Knu 1/0
SECOND SKIN
Whatever is cheaper, you will see very little difference in batts of this size unless u have a ton of them.
Pioneer AVIC-N2
or you can bite the bullet and get an alt and solve the problem at its source. if you're one of those people that just bangs it hard all day every day, that batt will get drained pretty fast and then you'll be back in the same spot. HO alt means that the issue is eliminated, not a symptom
Team DC
so would running a
ho alt, say 120 amps idle, 250 max, be able to handle everything with my regular battery? if so then that would be easiest
Current Setup:
Factory HU with LOC
Amp- sae-1200d
Show Setup:
Subs - 2 RE SE 15's
Box - 5cubes sealed
SECOND SKIN
RAYTARD in my opinion is correct. Get a HO alt (DC Power, Mechman, etc....) coupled with a secondary battery, will solve your issue as a whole. Might also give you marginal space for future upgrades......
I love my staffie :good:
So anti FACEBOOK it isn't even funny
  • Who's Online   0 Members, 0 Anonymous, 959 Guests (See full list)
