drewb53 Posted November 18, 2009 Report Share Posted November 18, 2009 what are some ideas for holding my box in place in my trunk besides drilling through the trunk and into the box? Quote 2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012 no. this is for converting dc to ac. useful if you want to run a blender inside your car. Link to comment Share on other sites More sharing options...
korey_hofer Posted November 18, 2009 Report Share Posted November 18, 2009 ratchet straps Quote previously known as wenn_du_weinst aka fucking internet coward supreme. I talk shit on other forums like a little bitch and hope i don't get caught out on the street. Link to comment Share on other sites More sharing options...
pRoFsWiRlY Posted November 18, 2009 Report Share Posted November 18, 2009 Lots and Lots of velcroe... like, the whole underside of your box! And make sure you get an industrial strength with large hooks, not the flimsy stuff Quote Ride - 2006 Scion xB Equipment: H.U. - Kenwood KDC-X793 Amps - Memphis 16-MC2.100 Memphis 16-MC1.1100 Front Stage - Memphis 15-MCC6 6.5 Components with silk dome tweets Subs - Memphis 15-M310D4 10" Sub (x2) Custom box 3.02 ft3 after displacement, tuned to 37 hz Big 3 Second Skin Damplifier Coming soon: Kinetik HC1400 H.O. Alt AudioControl three.1 Link to comment Share on other sites More sharing options...
drewb53 Posted November 19, 2009 Author Report Share Posted November 19, 2009 thanks for the suggestions guys.. any more ideas? Quote 2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012 no. this is for converting dc to ac. useful if you want to run a blender inside your car. Link to comment Share on other sites More sharing options...
S15_Silvia Posted November 19, 2009 Report Share Posted November 19, 2009 You could attach right-angle metal tabs on the bottom corners of your box, have threaded bolts coming up through the floor, and secure the tabs to the bolts with nuts. Just a suggestion. Quote 2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix | On 6/6/2012 at 6:32 PM, 'LZTYBRN' said: 3. Don't put speakers outside the car unless you are the ice cream man. My feedback thread Link to comment Share on other sites More sharing options...
drewb53 Posted November 19, 2009 Author Report Share Posted November 19, 2009 You could attach right-angle metal tabs on the bottom corners of your box, have threaded bolts coming up through the floor, and secure the tabs to the bolts with nuts. Just a suggestion. i like the idea, but i dont want to drill through the body if i dont have to Quote 2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012 no. this is for converting dc to ac. useful if you want to run a blender inside your car. Link to comment Share on other sites More sharing options...
LunatikGixxer Posted November 19, 2009 Report Share Posted November 19, 2009 velcro Quote 2002 Dodge durango 4.7L Autopage 2 way remote start alarm system 2 AQ 15 Aluminum coils. 1 AQ2200D (soon to be 2). 8.5 cubes tuned to 38hz. Yellow top under hood. Kinetik 1800 in rear. Big 3. (H/O Alt Soon to come) Kicker ZX200.4 Kicker 6.5 doors (blown) RF 6.5 comp set (soon to come) 1 run of Stinger 1/0 guage (soon to be 3) All of the above is all gone Currently own a 2000 Pontiac Trans Am WS6 No audio components. Link to comment Share on other sites More sharing options...
uhoh_45 Posted November 19, 2009 Report Share Posted November 19, 2009 we had this problem in my buddys car, he has easy replace headlights and all that at the rear bumper and so we just got some old angle iron i had laying around with bunch of wholes already drilled into it unscrewed the nuts placed the angle iron over screwed them back in (did for both sides) and used a ratchet strap and she holds tight Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
Marlo Stanfield Posted November 19, 2009 Report Share Posted November 19, 2009 I've always used med-large L clamps but you said u didn't want to drill into the box or body. You could use the ratchet straps as mentioned and they work pretty well, but they are very visable. I also knew someone who built a false floor and actually glued the underside of the enclosure to the false floor. It worked great and after it was all carpeted you couldn't tell that it was done. But obvious downside is that you can't move the enclosure without having to tear it out and start from scratch for the most part. Quote 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace Link to comment Share on other sites More sharing options...
drewb53 Posted November 19, 2009 Author Report Share Posted November 19, 2009 i agree, and my spare is still in the trunk also Quote 2003 Chevy Blazerkenwood headunit4 ga. kicker wiringAQ1200D amp2 12" DC LVL 3'sStinger Volt MeterMy Build LogBlazer is no longer. Totaled 02/14/2012 no. this is for converting dc to ac. useful if you want to run a blender inside your car. Link to comment Share on other sites More sharing options...
