i'm getting a sub that is only single 4 ohm or single 8 ohm... any way i can wire it to 2 ohm ?
some reason this is really confusing me... and i'm pretty sure i can with single 8 ohm right ?
Edited by Coolwazabi
No to both your questions with single 4 ohm and single 8 ohm coils.
If you want to run your amp at 2 ohms with a single 4ohm voice coil sub, you will need two subs.
If you want to run your amp at 2 ohms with a single 8 ohm voice coil sub, you will need four subs.
if i wanna run it at 1 ohm i need to get the 4 right ?
if you get the 4ohm versions yes it would take 4 of them to get to 1ohm. RF has a thing under the support tab thats a woofer wiring wizard to help with how to hook it up and the different ohms and subs. I always found it helpful
RF Punch 40x2RF Punch 100x2RF Punch 200x2RF Punch 200x2RF Punch 400x4JL Audio 10W7-3"but its only a 200 watt amp tho"
you cant wire a single 4 ohm sub to 1 ohm. its 4 ohm and you cant change that. you would need 4 subs in parallel to get to 1 ohm
DD M4
Rockford Fosgate P500-4
SoundQubed HDC415 w carbon fiber cap
2 Rockford Fosagate T1675-S
XS Power D3400 Under Hood
XS Power D5100 in rear
Michael Singer 200A Alt
Build Log: http://www.stevemeadedesigns.com/board/topic/153901-2012-veloster-update-842013-wall-build-4-15s/
no offense, but how hard is that to figure out. a $1 bill cant be changed into $2. you would need 2 $1 bills. a 4 ohm sub cant be changed into 2 ohm. you would need 2 4 ohm subs. its really not that hard people. ive seen this question asked WAY TOO MAY TIMES!!!
but u can change $1 in 4 quarters...
no comment on the stupidity and overlooking of the point.
yeah...
anyway
if i got a 2 channel amp i could bridge it for 4 ohm and it would work with a single 4 ohm sub right ?
yeah...
anyway
Yes.
1- T1000.1bd's
3 Maxx 29 deep cycles
4 runs of 1/0 gauge
-Big 3
All in a CAR.
  • Who's Online   1 Member, 0 Anonymous, 4382 Guests (See full list)
