LoudBlazer Posted December 4, 2009 Report Posted December 4, 2009 Anyone know of 2 amps that could be linked at 1ohm and play daily without issues? Dont see many 4k rms amps at 1ohm I like 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350
sayhuh? Posted December 4, 2009 Report Posted December 4, 2009 Anyone know of 2 amps that could be linked at 1ohm and play daily without issues? Dont see many 4k rms amps at 1ohm I like Wouldn't two amps linked to make 1 ohm have to be two amps that would do .5 ohm? You mean linked as in strapped? Blown
Marlo Stanfield Posted December 4, 2009 Report Posted December 4, 2009 Have you looked into an AB VFL400.1?? I run 2 of them daily and have had them for almost 2 years now, so any questions just let me know. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
LoudBlazer Posted December 4, 2009 Author Report Posted December 4, 2009 Wouldn't two amps linked to make 1 ohm have to be two amps that would do .5 ohm?You mean linked as in strapped? 4 subs 2ohms a pair, down to a final load of 1ohm, so I would have to do a 1ohm load into the amps. As subs as a pair correct? Like I did when I had my 8-12s 4subs at 1ohm and the other 4 at 1ohm to have a final load linked with 2 amps at 2ohm 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350
LoudBlazer Posted December 4, 2009 Author Report Posted December 4, 2009 Have you looked into an AB VFL400.1?? I run 2 of them daily and have had them for almost 2 years now, so any questions just let me know. How do you have yours wired up? 1997 2 Door Blazer Bagged & Body Dropped SBC/TH350
Boon Posted December 5, 2009 Report Posted December 5, 2009 VFL 400.1 is a 4k@1 amp... You could look into something like 2 SAZ-2000D's which would probably handle it if your electrical system was strong. But seriously, there are so, so many good 4kw+ monos out there these days that you may as well look into one of them. RF T4k DD M4a DD Z1a DD Z2 AB VFL400.1 AB VFL500.1 IA 40.1 Atomic AT5k Cactus 5k Sundown 4.5kd Memphis 4k Hifonics something-or-other The list goes on (and on and on) 10.x volts fo' life!
HHR Ed Posted December 5, 2009 Report Posted December 5, 2009 Why not 1 big amp that does over 8K at 1 ohm. There are alot out nowadays. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
Marlo Stanfield Posted December 5, 2009 Report Posted December 5, 2009 How do you have yours wired up? They're each wired @ 1ohm each, not strapped... They do over 4000w @ 1ohm all day long and are damn near indestrucable. VFL 400.1 is a 4k@1 amp...You could look into something like 2 SAZ-2000D's which would probably handle it if your electrical system was strong. But seriously, there are so, so many good 4kw+ monos out there these days that you may as well look into one of them. RF T4k DD M4a DD Z1a DD Z2 AB VFL400.1 AB VFL500.1 IA 40.1 Atomic AT5k Cactus 5k Sundown 4.5kd Memphis 4k Hifonics something-or-other The list goes on (and on and on) I agree with this 100%... Right now there are soo many high quality 4k or more amps out there, that there really isn't any point is stressing 2 2kw amps by running them @ .5ohm each. 1998 Ford Explorer Eddie Bauer... New setup, old ride... QX56 is staying stock til I get loud... It's only getting walled off if I don't meet my goal @ SBN. Pioneer AVIC-N2 (12) 12" RE SXs old model.... (3) AB VFL 500.1 @ 1ohm each Dual 300amp Ohio Gen alts.... (10) Northstar NSB-125s 26ft3 @ 33hz w/ a ton of port area 156.5 @ 40hz @ dash, Db Drag style / 153.2 Bassrace
Boon Posted December 5, 2009 Report Posted December 5, 2009 They do over 4000w @ 1ohm all day long and are damn near indestrucable. Heh, tell that to the one on my bench that blew every single MOSFET in the amp except for 2 in the power supply. 10.x volts fo' life!
