KnuKonceptz
Thanks for the advice man, i'm gonna be running that audiopipe sooner or later, but i have an power acoustik 1920 i'll be using till i get the other one.
Gonna be running 6 audiobahn 12 inch se natural woofers, rated at 400 rms, but more like 250-280 range.
Should i run 10 or 8 gauge power wire to the subs as well or will 12 gauge get the job done?
I have the KK 10 gauge speaker wire, I have also used some 8 gauge power wire for the subs.
Lunar Amplifiers: L1500's x 8, L2125, L100X2, L55x2, L40x2 (2)
Digital Designs 9518G x 2
DDA-W 6.5 components
DDCX 4 x 4
DDCX 5x7 x 4
Iraggi Amputator 260
ive never used alum wire myself i always use copper, but for most normal setups the klmx should be more then effective
cca = straight garbage... theres a reason its cheaper. consider yourself lucky james
just think real hard what the advantage is of copper clad aluminum wire and get back to me with it. because it doesn't carry as much current as the real 1/0 like it says on the page... so either your setup actually needs 1/0 and ur not going to be giving it Or your full of it and dont need 1/0 to begin with. You can do what you want but as long as your aware of the reality of it
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
If the fact that it is copper clad aluminum is a worry, just get the Fleks wire. That is pure oxygen free copper. I have used the KLMX wire and it seemed pretty good to me, but I'm also not running a 3000 watt rms setup (yet lol)
its only gonne be running at the very most 2000 watts, depending on the efficiency of the audiopipe amps
My current 95 Jetta Build w/
pioneer h/u
2 RD Sonance 10's with flatwind coils
2 Audiopipe apsm 1500.1s
1 Hifonics Brutus Elite 60x4
1 XS d925
1 Stinger spv35
1 1000 amp lead acid
50 ft of 0/1 ofc from Audiotechnix
all powerbass components, and coaxils, 4 sets
buildlog = http://www.stevemead...2-rd-10s-build/
My build for my wife. http://www.stevemead...01-f-150-build/
so youre saying this kit http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-AK0 is garbage? i would like to know before i buy it, my equipment is in my sig
1999 Altima 5spd
HU: Alpine CDA-9887
Frnts: CDT audio 6.5 Components
Rears: Alpine Type R 6.5 Components
Speaker Amp: DAT HR4125
Subs: 2 AQ HDC3 15's coming soon
Sub Amps:(2)US MD2D
Wiring: Stinger
i wouldn't say the klmx is bad although I use the fleks for everything except grounding my front battery to rear battery. BUT personally is i ran over 2500 watts (which i do) i'd do the fleks unless you run 2 runs of the klmx (it's cheap enough)
  • Who's Online   0 Members, 0 Anonymous, 1070 Guests (See full list)
