TheSundownFire Posted December 14, 2009 Report Posted December 14, 2009 I went from coaxials Memphis PR 6.5s in the doors to Boston Acoustic 6.5 components and i lost all of my mid bass. Theyre in Qlogic kicks which I know arent very sturdy but could that really make all of my midbass go to shit. I checked out all of the crossover points. Its like the speakers are moving like they should but theres no mid bass. Any help or suggestiond? 1999 Pontiac Sunfire Alpine CDA-9886 Sundown Audio SAZ-1000D Sundown Audio SAX-50.4 Rainbow SAC 265.25 Components Image Dynamics iD12 Optima Yellow Top SQFire FTW.
bobonit Posted December 14, 2009 Report Posted December 14, 2009 Those qlogics are usually pretty small, you might not have enough space for any decent midbass to develop. The door has more space. 97 Maxima SE Bunch of shit going in, check out the build Build Log
Boon Posted December 14, 2009 Report Posted December 14, 2009 Door speakers are made to play in an almost infinite baffle alignment. Not a tiny little sealed pod. That's why your midbass sucks. 10.x volts fo' life!
1030tooled Posted December 14, 2009 Report Posted December 14, 2009 With all the knowledge here, you could build your own kicks with the amount of air space needed. 93' Ford Aerostar Alpine head unit 4-5.25 MB Quarts 20-10" pyramids super Pro 1 Lanzar amp
TheSundownFire Posted December 14, 2009 Author Report Posted December 14, 2009 The kicks arent exactly sealed. They have a large gap in the rear. I assumed that would be enough for the kick to act like an infinite baffle. 1999 Pontiac Sunfire Alpine CDA-9886 Sundown Audio SAZ-1000D Sundown Audio SAX-50.4 Rainbow SAC 265.25 Components Image Dynamics iD12 Optima Yellow Top SQFire FTW.
jbondox Posted December 14, 2009 Report Posted December 14, 2009 uhm... how about flipping the right out of phase (reverse the + and -) yes speakers are designed to play infinite baffle conditions, but to lose all midbass you have other issues also for testing turn the x-over high pass off or down as far as it can go and bring it up while listening with your ears SMD SuperSeller VerifiedJbondoXJames Shields
Nightshade Posted December 14, 2009 Report Posted December 14, 2009 I recently switched to qlogic kicks as well and I like them. I still left my Kicker RS comps in the doors mounted coaxial style so that could be a reason why I'm not lacking. Actually I only went with a 5.25 in the kick instead of a 6.5 like you, but I did get the 6.5 kick panels and just cut out holes for 5.25's. The other thing I did was put Second Skin on the backs of them and it stiffend them up quite a bit. I also got more poly fill other than what came with the kicks and put that behind the woofer too. Mine may be a bit deeper than yours, but the midbass that comes from the kicks alone is pretty decent and they are not even 6.5's. I would check your settings on the deck or amp to see if somehow you've set a subsonic that isn't supposed to be set or have a crossover turned up too high. Are you running actively or passively? If your running passively then I'd like to suggest that you get a processor that will allow you to run actively. You will be able to fine tune the setup to get more out of it that way. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
jbondox Posted December 14, 2009 Report Posted December 14, 2009 you don't need to buy a processor... or anything else... try what I mentioned, and report back... or or do what i said with a straw hat on, put white stripes on your face, wear some straw around your waste, find a kids doll and make the hair stand straight up (glue or a rubber band) run around the vehicle jumping and shouting yoma yoma yoma... shaking the doll, then try it if the second way works and you did not try it the first way I mentioned... I will gladly change my forum name to Haitian Witch Doctor specializing in voodoo to fix your vehicle over the internet SMD SuperSeller VerifiedJbondoXJames Shields
tristan560 Posted December 14, 2009 Report Posted December 14, 2009 you don't need to buy a processor... or anything else... try what I mentioned, and report back... or or do what i said with a straw hat on, put white stripes on your face, wear some straw around your waste, find a kids doll and make the hair stand straight up (glue or a rubber band) run around the vehicle jumping and shouting yoma yoma yoma... shaking the doll, then try it if the second way works and you did not try it the first way I mentioned... I will gladly change my forum name to Haitian Witch Doctor specializing in voodoo to fix your vehicle over the internet Lmao...that made my day. <u>99 Jimmy SLT 4WD</u> Systemless. <u>99 Grand Prix GTP</u> DC XL 12 on 1.5k tuned lowwwwww.
Nightshade Posted December 14, 2009 Report Posted December 14, 2009 you don't need to buy a processor... or anything else... try what I mentioned, and report back... or or do what i said with a straw hat on, put white stripes on your face, wear some straw around your waste, find a kids doll and make the hair stand straight up (glue or a rubber band) run around the vehicle jumping and shouting yoma yoma yoma... shaking the doll, then try it if the second way works and you did not try it the first way I mentioned... I will gladly change my forum name to Haitian Witch Doctor specializing in voodoo to fix your vehicle over the internet You are crazy sir! I was also just adding that a processor will add flexability and should allow him to fine tune his mids to put out the type of midbass that he requires. It also may be a reverse polarity issue as you stated and is one of the most overlooked things that a person forgets to check when making an upgrade. A processor will not hurt any, it can only help if he is serious about having any sq in his ride and will give him more options than the passive xovers that came with the comps. 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
