Okay for the longest I didn't have my big 3 done correctly. Ihad the negative on the battery running straight to the engine block and all was good. After learning that I had it all wrong (about two months ago) I corrected it batt neg to chassis engine block to chassis. Now my voltage blows! I still see very little drop when playing but my voltage normally sits around 13.3-13.5 while driving. The birthsheet that came along with the alt says it is regulated to 14.7 and I never ever see that anymore.
System tear out has begun...Out with the old
i have a iq of 128 i graduated at the top of my class tell me how im reatrded you are the 1 thats dumb as hell you can't even spell
Look at the underlined text hahahahahahahaha
I think of it as the virgin losing the virginity technique
not just jumping in to it, and pounding away, but going at it slowly over time, to get to that full extreme
How many batterys are you running? Could be some of your voltage is going to charge multiple battery's better now.
Edited by JesseJamesDallas
Do a big 4 with a big 3 on ground alone, alt to bat +, bat to eng, bat to chassis and chassis to eng. you can never have enough ground wire run but this makes sure you have no weak spots.
01 Ford focus ZX3
Pioneer AVH-X491BHS
PPI PC 4800.2
Morel Maximo 6.5" x2
thats how your supposed to do it i thought.
alt to batt
batt ground to engine block
batt ground to frame
Edited by Kranny
Either thats a run on sentance.
Or he went from battery negative to engine block then to the vehicle chassis.
When he should of done battery negative to engine block/alternator mounting stud, then negative battery terminal to vehicle chassis.
Edit:
You had it right the first time, you where just missing the negative from battery to vehicle chassis.
And not do what you did from negative battery to engine block to chassis.
And you could take it all a step farther and run a Positive power wire from your battery positive to your main fuse box under the hood (it dont have to be 1/0 wire, but running something bigger then factory like a 2 or 4 gauge will help your vehicles electronics dim less).
More less what you did is "daisy chained" your grounds by adding the ground from your engine block to your chassis. This most likely added a lot more resistance and that resistance in proper grounding made your voltage suffer a bit.
Edited by Audiofanaticz
Oh I must have misread the big 3 tutorial. I looked at it and thought mine was wrong.
Thanks alot everybody. I'll get it corrected and give you guys an update tommorrow
Edited by Basshead08
its almost 2010 who reads tutorial anymore its all about pitchures
1. Battery positive (+) to alternator - From the positive terminal on your battery to the alternator positive (+) post
2. Engine block to chassis ground - From engine block to chasis. This is to strengthen the ground.
3.Battery ground (-) to chassis ground - From the negative terminal on your battery to your car's chassis.
BUILDLOG
http://www.stevemeadedesigns.com/board/ind...showtopic=61862
"98crewcab"Never a POS....just always "a work in progress" lol that's how we roll bitches!!!
Your a lowlife kid. I bet your mother wants to kill herself for not swallowing your ass.
How is your amp grounded? to the chassis or to a battery in the back? if its to a battery, how is that battery grounded?
If your amp is grounded to the chassis, or you amp is grounded to an extra battery in the back (and that battery is grounded to the chassis in the rear) then you should ground the engine to chassis and batt to chassis.
For mine though, I have 2 runs of 0 gauge ground to my back batts and ground my amps to those batts.
so for my big three i have
alt to pos batt
Engine (actually alt mount) ground to battery (for my amps)
Battery to chassis (for stock electrical stuff)
Edited by fritosaregood
My amp is grounded to my rear battery. The rear battery is grounded to the negative on the front battery, which is grounded to chassis.
  • Who's Online   0 Members, 0 Anonymous, 3000 Guests (See full list)
