DC Sound Lab Jeep Part III - <154.4 Bass Race>
get busy mother fuckers.
i have 4 dc 3000's, but running 2 amps im at .65 per amp, and they are so inefficient on 2 amps at .65 my voltage is terrrible!!!
but we know that i can hold 13.9 with 2 dc 3k's at 1 ohm. sooo i dont have the battery bank and will not to support 12000w rms, for autorama. But i know that i can support 6-8kw if the amps stay within their 80% efficient blah blah.
one SD8K at 1.2ohms will put out the same 6K i need but at a higher efficiency, so ill be able to do autorama with 2 group 31's revving to 2k all day and stay in the 13's instead of mid 11's.
then in a month or two with the addition of rear bags, i will up the battery count from 2 to 6-7 and then add the second 8k.
sorry my girls account this is Alpine btw
clamped are 8k at 4.4 ohms after ohm rise at 5265 watts you will get alot more than 6k at 1.2 ohms if your rise is low
I keep tellin em that Ray.....But they're lazier than I am. :lol:
A half-wit gave you a piece of his mind, and you held on to it.
anythings possible with the right build =] we accept visa and mastercard =]
We can set up your four amps to give you same power now but much, much more efficient and it will be reflected in your voltage.
Give me a day with the Jeep and you'll get where I'm coming from.
-Drew
R.I.P!
(Nov-29-2009)
92 explorer
current build
So the right rear door latch broke off.
it just few open.
So we had to rig a fix :) Tonight we're getting the Stinger meter wired in and HOPEFULLY tomorrow will be productive. Either welding or fiberglass or four amps depending on how hard dime wants to work :D
-Drew
