im screwed where do i start
it does suck but its the 4l60e and its known to have problems the guy who did mine was a GM master tech before opening his own tranny shop. WE bsed about it before he started and really knows his trannies. He warrantied it and I paid in cash. Small shop guys tend to like that approach. :D
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
shit i havent even driven it yet today wish me luck
2005 Ford Ranger Reg cab
Build in Progress
T3 Audio T2000 12
ARC SE4000
Stinger HPM 1/0 Wire
DC power 270xp
Batts: 1 Redtop up front and a Stinger SPP2250 in the back
Hopes to be in and around a 150....weel see
my youtube channel
http://www.youtube.com/user/steph3n1
Team DBs (Driven By sound)
Hey man if you have not drove your truck yet and its really cold where you live check your tranny fluid levels and before you drive let your truck warm up til your needle is half way between the hot and cold I found when i had that clunk noise the longer i let the vehicle warm up it didnt do that and since your not slipping outta gear i would say your friend is full of it abou only lasting 2 weeks give this a try and let me know...
Oh yea...you could do like above, but once your truck is warm..check your transmission oil and smell it. If it smells burnt, then your tranny is shot.
10501650_10203332501847103_1859383749711
Blown
Have you since tried putting it into reverse?
Its possible that the ecu tried to select the wrong gear when you put it into reverse, that would explain both the bad clunk and grinding noises you heard, also would explain why it still drove fine in D. Which in turn means there may not be anything physically wrong with it just a once off where the ecu got 'confused'.
Also if your transmission oil is burnt it doesnt neccasarily mean that the transmission is shot, it can also mean your driving it too hard.
yeah... tranny removal and installation is a cake walk on a truck... just make sure you have a good floor jack and a buddy or two to assist you..
http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774
93 Saturn SC2My system4 SA-15's Walled
2 Cerwin-Vega S2000's
3 Kinetik Hc2000's
Dual 200amp alts.
you guys done with the peepee touching contest or do I need to end it?
if yoru trans is shot get one and do it yourself.. if you can find a smnall jack you can put on your oil pan so you can suport it while the engine is out. and then pull the trans..
we did ours in our truck in our driveway. the hardest part is lifting it back up into the truck!
well just took it to a shop today and they got it fixed in 2 hours. it turns out it was a piece in the parking brake that broke off and was hanging up in my drums and wouldent let me go in reverse so its all good now only 85$ :D
Build in Progress
T3 Audio T2000 12
ARC SE4000
DC power 270xp
my youtube channel
